Originally Posted by
black roadster
Now if the guy tried to run, I might shoot.
channelmaniac
That WILL get you in hot water. You can't shoot 'em in the back as they run away!
Are you sure? I think you can as long as they have something of yours in their hand. Texas Penal code:
§ 9.41. PROTECTION OF ONE'S OWN PROPERTY. (a) A person in lawful possession of land or tangible, movable property is justified in using force against another when and to the degree the actor reasonably believes the force is immediately necessary to prevent or terminate the other's trespass on the land or unlawful interference with the property.
(b) A person unlawfully dispossessed of land or tangible, movable property by another is justified in using force against the other when and to the degree the actor reasonably believes the force is immediately necessary to reenter the land or recover the property if the actor uses the force immediately or in fresh pursuit after the dispossession and:
(1) the actor reasonably believes the other had no claim of right when he dispossessed the actor;
or
(2) the other accomplished the dispossession by using force, threat, or fraud against the actor.
§ 9.42. DEADLY FORCE TO PROTECT PROPERTY.
A person is justified in using deadly force against another to protect land or tangible, movable property: (1) if he would be justified in using force against the other under Section 9.41;
and
(2) when and to the degree he reasonably believes the deadly force is immediately necessary:
(A) to prevent the other's imminent commission of arson, burglary, robbery, aggravated robbery, theft during the nighttime, or criminal mischief during the nighttime;
or
(B) to prevent the other who is fleeing immediately after committing burglary, robbery, aggravated robbery, or theft during the nighttime from escaping with the property;
and
(3) he reasonably believes that:
(A) the land or property cannot be protected or recovered by any other means;
or
(B) the use of force other than deadly force to protect or recover the land or property would expose the actor or another to a substantial risk of death or serious bodily injury.
