Where do you get redline int metroplex?
Originally Posted by Champion1
http://www.redlineoil.com/dealers.asp
Quite a few of us are really fond of Mobil One Synthetic over Red Line. YMMV!Quote:
I am about to do my first oil change on the new car the guy before said he used Castrol 5w 30 weight, what would you guys suggest for my naturaly aspired 1.8 99' model?
Look upQuote:
Mobil One Synthetic
You can solve this by routing EPS conduits through the main deflector.Quote:
Originally Posted by OUTRACE
Mobil 1 synthetic...ok
please forgive my ignorance I have never used a Synth.oil does it come in different weights and if so what weight.
How many miles does one oil change get you using Synthetic oil.
I should also mention that the engine has 38K would that make a diffrence being such low miles?
Thanks for all the help, I am learning so please just be patient with all the questions,.. and as I mentioned should anyone have a question about Optical related issues I am an expert in that field and would be happy to answer any questions. or about music or music related issues.
Yes, it does come in different weights. I'd probably recommend 10w-30 for a street driven car, as it works and it is usually the easiest weight to find. I use 0w-40 in mine for a car that sees a lot of abuse.Quote:
Some people will say you should be able to get 7500 to 10,000 miles between oil changes on synthetic oil, but I'm a big fan of changing every 3000-5000 miles regardless of whether you use dino or synthetic oil. Primarily because I wouldn't want to go 7500 miles between filter changes, and also because I look at fresh fluids as cheap insurance.Quote:
Nope.Quote:
No problem. :wink:Quote:
Thanks a lot Altiain...
I kind of get on the car a bit too should I maybe change the oil weight a to something other than what you recomended?
However I am sure I dont abuse mine like you do since I am not racing it in autoX yet or even open track.
once again I appreciate your the patience and great advice I have gotten from the guys at MME
