Did you swap the CPS sensor with bmcreider's car to see if the CEL goes away?? FWIW it is a quick easy no cost test to eliminate the CPS as a possibility.
Yea car runs great. I will swap the cps sensor with bmcreider and try to find more info on the vvt.
Swapped the cps sensor out with bmcreiders and the same code still came up. Anyone know how to check the vvt?
