Eh, I disagree. When I worked at a shop in NJ with a rotor cutter, there was a kid working there that couldn't cut a rotor to save his life. Yes, it's a VERY basic machine, but there are plenty of ways to screw it up if you try hard enough.
For the Miata, rotors are so cheap, just buy new ones from Napa. I think they are actually cheaper (or damn near) than the cutting IIRC.
Just take a peek at the usual things: brake lines, ball joint boots, all the bushings in the area, axle boots in the rear, shocks for leakage...basically at least glance at any wear item.
Anytime I have the wheels off the ground I check the tie rods, wheel bearings, and ball joints using the "shake test."
