Get on the gas early, way early.
I will have Sammm in my car. Otherwise, it would have been fun to do a head-to-head comparison.
That last sentence probably sounded kinkier than it should coming from me.
::Banana::Quote:
Thank you for registering. We look forward to seeing you on Jun 22nd! REMEMBER - because you registered online you don't need to wait in the registration line at the trailer. Just sign the waiver when you arrive, check off your name on the registration list (it will be hanging on the side of the trailer) and get your car tech'd. That's it!
It's even easier if you have annual tech!
N!
Dang...S2000's must be fragile::Fart::
Yeah we developed a front end clunk, pretty sure it's the endlinks. New ones going on tonight. I'm pretty sure our alignment is still good, or at least I hope it is...
No soul mall queen???
Preliminary Run/Work order:
As most of you know, autocross is a sport that is supported & run by the participant. If you’re driving at our event, you’re expected to work at the event, too. Below is the “Run/Work” order of the day forevent #4. As much as possible, we try to rotate the order for each event.
The current entry level is allowing us to go to a 4 heat Run/Work structure. Any changes will be announced at the mandatory 9:00am Drivers Meeting held at the Timing trailer on the day of the event. TECH INSPECTION CLOSES AT 8:30am!!
Run Heat 1 / Work Heat 3
CS, GS, BSR, FSR, ASP, XP, EP, SMF, CM,FSAE, JA, JB, JC, X
Run Heat 2 / Work Heat 4
SS, DS, ES, HS, CSR, GSR, FSP, STR, BP,FP, SSM, DM, KM, CAM
Run Heat 3 / Work Heat 1
AS, DSR, HSR, BSP, CSP, ESP, STF, STS,STX, CP, GP, AM, EM, T, MAM
Run Heat 4/ Work Heat 2
BS, FS, SSR, ASR, ESR, SSP, DSP, STC,STU, DP, SM, BM, FM, W
Paddock & Grid locations: Paddock location for the Bus Lot events is the large parking lot just North of the Bus Lot (corner of Victory Circle & Allison Ave).Grid location will be on the Bus Lot on the Northwest corner. Additional Grid information will be provided at the drivers meeting.
Live Timing: Results should be uploaded as they are scored in the computer throughout the day. You’ll be able to view live results with your smart phone, tablet or computer during the event!
Live results during the event will be available at: http://sololive.texasscca.org
If you’re new to Texas Region Solo events, please take a moment to look thru our FAQ page before the event:
http://texasscca.org/soloautocross/solo-faq
Texas Region Solo on Twitter:https://twitter.com/TexasSolo
Texas Region Solo on Facebook:https://www.facebook.com/texasregion.solo
The weather sucked, but the event ran smooth for the most part. I'd like to see that course again in the dry!
Thanks for the rental Jimmy!
Official results are posted for TX Region SCCA Event #4 - Sunday, June 22nd 2014:
Final Resultshttp://texasscca.org/2014_solo_results/tr14_4_final.htmPAX Resultshttp://texasscca.org/2014_solo_results/tr14_4_pax.htm
Thanks to everyone that attended!!
Next Event: Sunday, July 20th at Texas Motor Speedway. See ya there!
Was fun running in the wet stuff. Another nice job by the SCCA gang. Good times. Thanks!
Good event. Frustrating to see another event where one heat has completely different conditions (and times) than the rest of the field, but that's just crazy weather luck. Very nice that the day was incident-free, and the only scare was a lo speed spinout by the IROC. Terrific course.
Great course and a well run event. Ran 2nd and worked 4th -- it was like two different events.
I sure would love a crack at that course in the dry...
Overall a fun day, but time for new tires (drink, OZMDD!). Still, Jon and I made the best of our own little battle to not be DFL in STR. Kudos to keno for top PAX and to Ryan M and John C for putting on a show at the pointy end of STR!
