More like a 7/10ths truth. The other 3/10ths truth is that there is always someone faster than you no matter how good you are. Just imagine if Mark Daddio showed up and wanted to co-drive with you.
Actually, I promise to use more optional walloms!!
Perfect!!
Q - Can you DNF on a course made exclusively from optional walloms?
Seems like plinko. Start at the top and end up at the bottom. This time there will be no FSAE hulks to avoid.
I'll be there!
If you hit a cone it's a cone, if you go thru the wall without taking out all the cones it's a DNF unless you go back thru or before the hole in the wall you made. Not sure about the before part some people/clubs think you have to renter the corse where you left it.
Go thru the middle without taking out the end cone DNF. Go thru the middle and take out all of the cones to the end of the wall, cones.
I really love where this is going. Starting to consider the all-wallom idea for real...
Please no.Quote:
:burnrubr:
Online registration closes tonight at midnight. Registration is available on the site from 8-9 AM.
Yes.
I'm in, only 2 STR cars so far. Where are the rest????
They are scared of you.
As well they should be. Brad is a scary guy.
Well I tried 3 different credit cards every singe one came back with
All were valid none were expired...Quote:
CC Processing Error: Declined
Error: The credit card has expired. (Reason Code 8 / Sub 1)
So I guess I'll sit this one out.
I'm in, but always do onsite reg. POS will be there as well, so he can mentor MiataProtege.
Gebus Christianity tried it another 1/2 dozen times and low and behold AXware has finally decided to allow me to register using the same freaking credit card it told me had expired the prior six attempts........ ::Rant::
It is enough to piss off the Pope! ::Censor::
No way MiataProtege will show. ;)
ONline registration closes at midnight on the Friday before the event. AXWare has some bugs too. We offer registratoin on site from 8-9.
Thanks,
We meeting at Mickey-D's or Einstein's in the morning?
Bring me a Ken Block RC car. Thanks!!
I'll be at Einsteins at 7ish. And I am bringing a car from work. Maybe I can get a fun run with it.
Einstein's depends on when I get in tonight. I will be there at 7 or the venue at 8.
course map pending... check back here shortly
http://cdnimg.visualizeus.com/thumbs...234e00e2_h.jpg->http://inlinethumb11.webshots.com/47...600x600Q85.jpg
Just trying to get an early start! ::Banana::
well played, pos.
