I just acquired a RB header and picking up the FM exhaust on Saturday. Now I just need to get them put on!
Cool can I bring the plasma again? :)
oh wait its a tech day not destruction day....
http://www.tractorsupply.com/home-im...sembly-3002001
Or 1lb bottles will work. At full blast, it goes through a pair of bottles in around 4 hours. ;)
Just finished buttoning things back up and taking a test drive. FCM bump stops, MazdaSpeed motor mounts, and a new o2 sensor installed.
Impressions-
FCM Bump stops rock. Huge improvement. My back already feels better.
MS Motor Mounts- A lot less shaking when you are not running on a broken mount. BITCH to install drivers side mount. For those thinking about doing it, do your self a favor and remove the header right off the bat. I got the old mount off and the new one in place with the header on, but couldn't get the bolts back in without removing the header (which requires the supercharger coming off for me). I figure I wasted at least 2 hours trying to work around the header vs if I had just pulled it off to begin with.
O2 sensor- running much smoother now with a steady O2 signal.
Glad you have it running better. It sure was running rough and hard to start. At least you have the less expensive one-wire O2 sensor.
4 wire conversion is required for my link ECU.
