You can buy pre-mixed 50-50 antifreeze at VatoZone. 1 gallon is all you need.Quote:
I know I already said it once before, but a radiator cap is another thing you should replace. They are not a lifetime part, and if they are bad they can cause your Miata to overheat and the radiator to drain, isn't that correct Kestrel? :wink:
http://forums.dfwmiata.com/viewtopic.php?t=1225
I love that pre-mix junk... saves alot of headaches.Quote:
Originally Posted by sammm
I wish I could use the pre-mix. I need 70/30 in the turbo with water wetter to keep the heat out. I still might be cutting the hood to make an extractor hood.
