Sweet - I took 9th out of 199 in the overall PAX. The funny thing is, I was never quite happy with the way the car was set up. :D
Not only did it shut down my email until I downloaded the 6 MEG files, but POS may be hearing from my ISP's lawyers :PQuote:
Can someone explain the m after the place & T for trophy slots on the results posting?
1Tm 8 Keith Starr
2Tm 7 Jim Hollinsworth
3Tm 4 Charles Cram
4 m 99 Damon Bottorff
I've only been doing this for a couple of years . . .
more masculine than Hal?
I'm guessing member
So how do the numbers work? The time for three runs and then that last number means what?
The last number is the best run of your three, which will also be the run time highlighted in bold out of the three run times.
Since you run tire class the last number is your best out of the 3, with the PAX factor factored for your car class on that best run.Quote:
We can use onethings numbers an example :
Position # Driver Car Model Runs: 1-3 Total
5Tm tcs 16 :pig: 01 Mazda Miata 40.380 40.273 40.348 32.661
So his best run was 40.273 times a CS pax of .811 give you a 32.661 time.
The 2004 PAX/RTP Index "Racers Theoretical Performance"
http://www.scca-chicago.com/solo/indexes/rtp2004.html
So PAX being a sort of handicap?
Damn... I should have run in novice class.... ;)
Yea is a factor used to level the playing field, so you can compete against like a Z06's and still be competitive versus just using raw times.Quote:
Don't think so...I got an m, but I'm not a member. 8th place out of 20? .....not bad, not good.Quote:
Could the "m" mean that you've pre-paid the season? I have no idea why that would be an "m", but if it's not "member"...
Did I count right? Were there 18 Miata Pilots out there (6CS, 1ES, 2DSP, 5T, 4N)? :shock: Awesome baaabyyy!! 8)
