Originally Posted by
cwisenheimer
It's been said, but if the floor of your trunk is wrinkled, be ready for a total. Cars today are designed to crumple in a controlled fashion to absorb the energy of a crash so your body doesn't have to. The structure of the trunk floor and the main "frame" structures under the trunk absorb a lot of rear-impact energy. If they're bent, they can't just be "un-bent" and absorb the same energy next time. For the car to be repaired correctly, they have to be cut out and replaced with new metal, which is expensive and can easily lead to a total on an older Miata. I lost two that way. Note, the pieces *can* be "unbent" and the car will appear to be fixed and it will be cheaper -- it will also be less safe and if you knowingly tried to sell it that way, you would be liable for injuries to a subsequent owner, should they be rear-ended and hurt.
As for the value of the car, look at KBB or Edmunds for ballpark values. The value of your loan, the purchase price, what you'd sell it for, etc. are all irrelevant. The insurance company will tell you what they consider to be the value of your car, both for deciding whether it is worth repairing and for the value they'll pay you if they total it. This value WILL BE low, just expect it. You can argue, you can show your own market research, you can even get an appraisal, but the insurance companies make the rules and they generally win. When it comes down to it, what recourse do you really have? Not much. You can haggle with the adjuster, but the adjuster will only have authority to go to a certain amount and then it's over their head to their supervisor. Most likely, the adjuster will be a nice, honest, reasonable business person with a job to do. Treat them with respect and honesty and you're likely to get the best result. If they want to total it and give you less than you feel is reasonable, ask the adjuster what their limit is. Then ask how much the adjuster is allowed to give you for injuries. (Note that I didn't say to lie and claim to actually be injured.) If you can live with the limit plus the amount they are authorized to give you for injuries, tell them you'll take that much. If you can't live with that, let the rest of us know how you got more.
Your best outcome will likely be to get it fixed and back to you in good condition. You were happy with it before the accident, so you'll be happy to be back in the same situation. If you are allowed to get it fixed, make sure the body shop does the job to your satisfaction and don't accept it back until it's correct. Caliber on 7th in FW did work for me several times (not lately) and I was always pleased with their work. Also, while it's being painted, if there is any other paintwork you want done, you won't find a cheaper time to do it, since some of the prep will already be done in order to fix the rear. Good luck.
