Well then, lesson on how to install shocks are open for registration starting Monday.Quote:
Originally Posted by altiain
All that wrenching leaves room for a slip and a busted knuckle or whatever. If you know how to do it, blanket method takes half the wrenching. for instance, no little blankets...I'm using a very large and think U Haul blanket. A lot of things can be done better, faster, or more efficient but are not always done in those ways since many people are not competent enough to safely carry out the task. Guess I should be careful dispensing information these days. I'll have my attorney friend whip up a disclaimer just in case; don't want one of those "McDonald's" lawsuits.
Okay, that makes sense for tightening them, obviously wouldn't work with the shortcut removal method. That would be better than holding the shocks on the ground to tighten the spring compressor....need to get a bench vise for the new place.Quote:
Originally Posted by altain
Wait a minute....didn't you guys install FM springs? I didn't need a spring compressor to install them. I used it to take the stock ones off. At least the set FM sent me were short enough to not need it to put them on.
*nevermind, forgot you had an NB
