Imagine this...Quote:
http://home.comcast.net/~sammm/harness.jpg
mounted. :nutkick:
mounted. :nutkick:
Nah...
I rather see how you mounted the anti-sub belt. Also, how you incorporated the lap belt with the current stock set-up.
But maybe, just maybe, I'll imagine... ;)
Note for future installers....when mounting the sub-belt, don't do the logical thing and put it dead center between the seat rails. There is a frame U-channel under the car that will render that hole useless. It will have to offset by ~2.5" left or right to miss the channel and allow the large flat backing washers to be used. I used 2 washers (1 inside and 1 outside) for the sub-belt and the right side lap belt hole drilled into the tranny tunnel.Quote:
