Hello my name is joshua koshiol im new to dfw miata. I was wondering if anyone knows of a good place to get a used 92 miata transmission, I would be very appreciated if someone could help me out.
So what did you do to kill the original transmission??
Welcome to MME!
he bought it off CL ...
hehe :-)
I bet Jim at Town North Mazda has one (He parts out 90-97 Miatas)...I don't have the number up there though...
might try mazda/nissan heaven it is a long drive for you though
Joshua, just so you know... any Miata (excluding the NC) transmission will fit, they're all interchangeable. Doesn't have to be off of a 92. Try Planet Miata, they're $300+ shipping - http://www.planetmiata.com. If that doesn't work try the parts group - http://www.partsgroup.com, there's one on their site for $150+ shipping. If neither of those work for you try Cragslist, Ebay, Miata.net, Clubroadster.net.
Are you 100% sure it's the tranny? It would suck to put a new tranny in there if all you need to replace is a slave cylinder or something.
may as well order a clutch kit while you have it out too
It's pretty rare for a transmission to go out... unless you are running a big turbo or supercharger. Most likely you have a failed hydraulic clutch slave cylinder.
What are the symptoms?
it has fluid in it right ... (speaking from experience ;) )
I'm wondering too!
I have a couple of good tranny's...PM
poor rogue ..... he is so confused ;)
::Blowup::
you know you gotta watch what you say and how you say it around here man
Just wanted to say i appriciate everyones help with my transmission issue, i guess i should have listed whats wrong with the transmission, its got a brand new exedy clutch and fidanza flywheel so i know its not that, it also has a new slave cylinder, whats going on is say your in fith gear and you drop the car to fourth the tranny will make a lound grinding noise when coming down through the rpm's. The shifter also got stuck in reverse awhile back, you could put the car into 1st but the car would still stay in reverse and only go backwards, that was my problen with the shift fork.sorry if im not explaining this well. I got under the car to make sure the slave cylinder was working proper and to see if the tranny had fluid all was good. If anybody has any suggestions fill free to tell me if im missing something, im not going to lye i dont no how to rebulid a transmission and im lost at what it could be.
Thread merged with original help thread. -Majik
Cool.
We wanted to make sure all the usual suspects were checked before coming to the conclusion the transmission was bad.
It's common for an early 90 model transmission to get stuck in reverse but the grinding noise is not. I wonder if VFR750 or one of the other guys on the board that part out Miatae have a transmission to sell.
no trans here.....................I only have a Torsen left at this moment.
If as mentioned earlier ALL tranny's fit, I have one.
How much for one of those installed? I have a severe gear whine with any acceleration 1-3rd and 5th gear but not fourth. I think my throwout bearing is also dying, it has a loud whirring/slight rattling noise with the clutch out in neutral, goes away with the clutch in.
Cool the 5th/Reverse lockout problem! I've had that happen a few times...one of these days I'll put my new tranny that's collecting dust in the corner of the garage. Mine also grinds going into 5th gear, you have to ease it into 5th a certain way or it grinds. I got my new tranny from Eric Japan for $200 but he gave me a deal cause my friend was buying the engine it was still bolted to.
