I thought there was an old thread about this, but I can't find it. My truck (Ford) needs some work. Anyone have a mechanic on the westside they trust?
Texas 10 has always done right by me. They're at Hwy 10 and Precinct Line.
What seems to be the problem?
Your going to pay someone to work on something you own! ::Shocked:
Repent all Ye Sinners Repent the end is near!
What did ya break on the truck?? ;)
Just to document a few other recommendations I got -
Gerald's Garage - 160 Bedford-Euless Road
2nd Opinion - 1936 Carson St.
Jewel Automotive 820 at James Ave. 817-924-1776. Talk to Mike and tell him Brenda sent you.
I posted this on a Ford truck forum. I know it's a longshot, but you never know....
My truck has been throwing a CEL P0443 code (EVAP system). Truck runs fine, idles fine, no problems. The problem is it's due for it's yearly inspection (Texas state law) and it won't pass with an active CEL. I replaced the purge solenoid valve and it is still happening. I finally took it to the dealer for their diagnosis. They told me the ECU needs to be replaced, but it's discontinued thru Ford.
I found remanufactured ones (Rockauto.com and NAPA), but still have a question. There is a calibration sticker on my truck that reads "7-43E". There is also an ECU code sticker that reads "EEA2". Rockauto and NAPA bought use the 7-43E number for the correct flash. Is that all I need to match so I can just swap one for the other? Would any other programming be needed with the replacement ECU? Is the VIN info stored in the ECU?
Wow Ford Discontinued the ECU that sucks!
I'm thinking the Ford Forum is going to be your best bet they always had great information back when I would find myself walking the last little bit to work when my Expeditions would die, good times good times!
Update - My Fleabay ECU replacement fixed my EVAP code. Passed inspection today! ::Banana::
FYI - Inspection doesn't care if the VIN of the vehicle doesn't match the VIN in the ECU. As long as the vehicle VIN matches the previous inspection tag it's all good.
Congrats!
