They are now forecasting up to 5" for the area, and it has already sleeted enough here in the past 15 minutes to make road surfaces slick.
Here too... my lawn is white.
::Rain:: It's just raining in Euless.... for now.
Can someone explain to me the difference between rain, freezing rain, sleet, hail, and snow? Out it California, we just had rain and snow.
I can't BELIEVE I chose this time to drop my Miata with Rogue to get the new finish panel painted and installed. This is going to be the best driving weather of the year, and I'll have to use a FWD Integra ::Bawl::
Rain: falling water (you really needed that one?)
Freezing rain: starts as snow, falls through a warmer layer of air and melts, then refreezes as it approaches the ground.
Sleet: sorta like baby hail
Hail: big enough to tear stuff up
Snow: frozen water with crystalline structure
Rain = water
freezing rain = water all the way to the ground, freezes on contact with ground
sleet = water to lower atmosphere, freezes in lower atmosphere before ground
hail = freezes and is lifted by updrafts (getting bigger all the while) - requires thunderstorms for the updrafts
snow = freezes in upper atmosphere
::Rain:: Yep, had some sleet here in Bedford. I thought I'd be able to get out today, but I'll stay in.
:reindeer: I will be driving tomorrow morning about 5:30 to get to work. I'm leaving early and driving slow!
Wow that map is amazing... didnt think DFW would be in the 3" - 5" band!
Probably 3" at Propwash already!
Rain - Liquid Water when it hits the ground, and stays so.
Freezing Rain - Cold liquid water that about to freeze, that hits when the ground (or whatever object is around) and the air near the ground is below freezing, so the water freezes on contact.
Sleet - Snow that has melted on the way down (due to a warm layer aloft) that refreezes as it passes down through another cold layer, and hits the ground as small grains of ice.
Hail - A large chunk of ice that forms like sleet, but in a thunderstorm, so it gets lots of melting/re-freezing opportunities, so gets bigger than sleet.
Snow - Co-joined ice crystals that form in the upper regions of a cloud and do not melt on the way down.
Snow Pellets - Snowflakes that partially melt and freeze together due to a shallow warm layer above the surface.
Hope this helps.
Real Snow, I can't believe it! :clap:
today i have seen....
heavy sleet
Heavy snow
and now a mixture of snow, sleet, and rain at the same time.
Well, looks like it is snowing hard here now.
We have had only rain here on the south west side of the metroplex.
::Censor:: You guys are horrible. At least I can still get out there in the Teg... it just won't be the same though. Rogue, you done with that thing yet?? ;)
Sad part is, I could have just dropped off the finish panel for him to paint but I elected to have him install it, too :banghead:
Update: It's coming down hard here. The snowflakes are about 3" in diameter ::EvilBana
Now it is snowing pretty hard here too.
