Is anyone rocking these here?
If so what size are you running and what tires?
I'm getting close to needing new tires and was thinking about upgrading to a set.
Post pics too.
Chris
Post pics too.
Chris
According to Wags, that's the one thing my car is missing. :confused:
I've got them on mine in a 15X8 with a machined lip running 225/45/15 RS2's. No pics, but they really fill our the wheel wells nicely and do not rub at all.
I have a set of silver 15x8 with 205/50/15 RT615's. They look great, strong and light, love mine.
I say 15x8 is great if you plan to run wider tire 205/225, the extra width gives your a bigger contact patch and sidewall support. My 205 Azenis could run at 26psi with no rollover.
But if you plan to run lesser tire like the 195 RE01R's, 7.5 width maybe better choice.
Alan
Best wheel for the money for a miata!
Get a 7.5" or 8" width. Both will support a 225 tire with no problem and both fill the wheel well nicely.
Since your car is a turbo, you might want as much contact patch as possible.
I want a set in the new "matte bronze". It's looks so bad ass!
I didn't know that they were available in 15x9!
linkie
If you really look for it, you do see the sidewall bulged out abit. But I can tell you the 205 RT615 works really well with the 8" 6UL.
Have not driven back to back with the same tire on a narrower wheel, but I suspect the wheel makes the tire so much more stable.
I've currently got the 205 Azeni's on a set of 15 Rota Slipstreams. They seam to fir the Rota's perfectly at either 6 or 6.5 inches.
Apex, you have any close up pics of your Azenis?
Chris
no need...
original thread
That reminds me I burn through a set of azenis in one year. :burnrubr:
Thanks Cosmo;)
6ul's are on god's chariot.
