Originally Posted by
Nails
Yea umm ok. So you guys feel your head is worth $350 as opposed to $40 huh? By that logic, seems you'd want to spend more on your helmet. You miss a month's work due to head injury perhaps you should spend a months salary then?
Anyway, most snell approved helmets 2000 or later have snell on the back where it says DOT. But, officially, they have to have the sticker inside somewhere w/ a serial number on it. You'll be looking for a tan M2000 or M2005. Gently pull back padding and you should find it inside.
I got an HJC CS-5 Snell 2005 with the protective sack for $48.30 total on Ebay. No lice in it either but if you're worried about it you can probably get it dry cleaned or use a febreeze do-it-yourself kit.
