i do not compete in any events yet am trying to be cost effective in my shopping. will simply the hardbar pass for use at msr or ecr or do i need the hardbar sport? thanks :)
It is really going to dependant on what each track and the group holding the track day have set for a standard.
I know I have run track days in the past with no roll bar at all just the hardtop on the car.
Do any of you track junkies have any insight on roll-bar requirements?
Unless it's one of the clubs that makes your helmet be 2 inches below the rollbar, my hardbar has worked for me to run top down at every event I've been to. Some may make you run with the top up.
That should work for most events. The only track that required something more was Laguna Seca, where we had to have a bar with rear bracing (like a Hard Dog Hard Bar Sport or Hard Core).
If you are going to buy a roll bar get the one thats SCCA approved that way you are covered if you want to do a SCCA event. The little extra cost is worth it in added safty. It will save you money in the long run not having to buy a 2nd bar when yours is not good enough. Safty is not were you want to cut corners and save a little money.
Robert,
Technically, the SCCA does not apprive roll bars. However, you should buy one that is built to the SCCA General Competition Rules (GCR) guidelines.
The Hard Core is GCR compliant, don't know about the Sport. The basic hard bar (2-point bar without rear supports) definitely isn't, and some organizations won't accept a 2-point aftermarket roll (style) bar.
I would suggest at least a Hard Dog Sport with the rear supports and at least one diagonal. I had a Hard Core bar with double diagonals and never had any issues at any track I went to.
So Altiain the ones listed as Solo 1 compliant would be your best bet??
Good Stuff below:
I don't know if you have any interest in autocross but for SCCA events you can run without a roll bar in stock, ST and SP classes but you cannot run with a roll bar that does not meet SCCA requirements.
for the time being i dont plan on traveling with the miata to any other tracks because i already have a track car, its just down for the moment... although the thought is intriguing...very...in fact... hmmm....yall are putting evil miata thoughts in my head now LOL!
:burnrubr:
:D
and thanks everybody for all the feedback, if there is more to be said go for it, i appreciate the help.
http://www.bethania-garage.com/images/hbv.jpg
Where are points 3 & 4? The seatbelt anchors? :scratch:
Generally speaking, a 4-point bar is a main hoop with two rear supports. You can argue that the Hard Bar technically contacts the frame in four places, but any track that actually has a roll bar requirement is going to tell you to go pound sand.
Go pound sand iain. Yes the bar does go down behind the seat. My point was it's not a style bar. Thanks anyway.
Aww c'mon Chris - you get snippy with me, but I can't get snippy with you? Love ya buddy! ::Daisy::
I didn't mean to imply that the Hard bar was a style bar. I meant to imply that any 2-point roll - or style - bar would not pass muster at any track that requires rollover protection.
:snack:
IIRC, the Laguna Seca regs required a "6-point" roll bar, and my M2 Sport bar passed muster. So, yes, it turns out that they counted the two points on the seatbelt towers. I woulda called it a 4-point bar. Go figure.
I wouldn't trust a true style bar to do much but mousetrap my ass in a rollover. I'd definitely feel better with Sharpie's Hard Bar.
See? ;)
http://www.bethania-garage.com/image...h_hardbar3.jpg
::Daisy:: Nothing to see here folks. Some misreading on my part and some engineer in Iain ;)
went with an ace bar and had them add a harness bar. I discussed on the phone that they can custom make the rollbar and harness bar i wanted fit with the glass window, went over measurements and everything. they were very helpful. good business.
That's a good point. Hard Dog will custom make a bar for you if you want, and the price is very reasonable. Several years ago, 71dsp had them custom build a bar for his wife's '99 Miata. It was a double diagonal Sport made with Hard Core diameter tubing and a custom fabricated 3-bend harness bar that attached to the main hoop uprights on both sides. They also agreed to ship it unfinished so that he could get it powdercoated locally.
I think one of the other members on this board (Adam?) ended up with that bar, but I have no idea where it is now.
