http://i5.photobucket.com/albums/y17...frontclose.jpg
http://i5.photobucket.com/albums/y17...tagvafront.jpg
http://i5.photobucket.com/albums/y17...atagvarear.jpg
Why was your lip in Japan??? :confused:
Get some day pics to show off the gv lip.
Looks great!
Good choice.
These are bad too... ::Banana::
http://www.indiabizclub.com/uploads0...s130799122.jpg
lol, good point about the palettes. Daytime pics are coming in a couple of hours or so.
It is difficult to get an aggressive / artsy angle on the car that shows off the lip and trunk at the same time.
over night!!! that makes it like a $2000 lip
How tough was this to install? I have one for my 99, and after playing around just a bit, it seems fairly easy, but it seems like I will need an extra few sets of hands.
If you are at stock ride height, all you have to do is slide yourself next to the bumper perpendicularly so that you can reach one arm under the car and into the bumper cover to push the bolts through the holes you drill so that you can take the other hand and attach the nut.
It isn't a comfortable job to do, but it's possible.
edit: The holding up the lip was done by putting in the end screws/clips first in the fenderwell, then using anything of the right height to prop under the lip and hold it to the bumper cover.
Looks damn nice
Binder clips work great.
Nice!! Keeping it black?
+1 Looks great. :D
+1 Binder clips or little clamps = easy to install. :D
-1 Mine shattered into several bits during ax run (yeah, I know, try and avoid the cones...)::Rant::
A cone destroyed your GV lip? Wow.
One more pic from today because I felt like it was ok, not as good as the others though...
http://i5.photobucket.com/albums/y17...arkedsmall.jpg
Looks great but house house need paint!
Double sided foam tape.
It will hold secure while you drill (spring clamps allow for too much squirming). If you clean the bumper and lip before applying the tape, it is easy enough to remove/reposition for fitting the lip. If you leave the tape in place after mounting, don't expect that lip to be easily removed.
