Stripped or cross threads on oil plug
The oil plug on our 1995 Honda Civic DX has either stripped or crossed threads. The plug is holding for now, but I need to change the oil. I have a few options:
- I can drain the oil and use a Tap and Die ($50 for a set with a big enough size). I will grease the bit in order to help capture any shavings, re-run the used oil through the system to help cleanse it, and I will also let the filter do its job.
- Buy an oil-plug repair such as this, but it is over $100.
- Take it to an expert.
Has anyone ever worked for a oil change place that has had experience with this issue? Perhaps there is an easier solution. Or, perhaps I should just have the oild change place fix it since they probably encounter it all of the time.
Comments?
