http://inlinethumb59.webshots.com/48...600x600Q85.jpg
You are welcome to join us for Challenge Cup number 6 on July 29th at West Mesquite Memorial Stadium. More information is available on our website at www.autocross.com/er
Thanks,
Thanks,
I will be there.
Don't scan that barcode. It's a naked pic of Andy!
Here is a direct link
http://inlinethumb26.webshots.com/51...600x600Q85.jpg
Hopefully I'll be there! Need to buy a car first.
edit: have a car and registered!
In.
I want to register for this but I need some classing help with my '97 Miata. This will be its first autocross (in my possession at least, but possibly ever). I think I'm in STR or CSP. Current mods:
15x7 wheels running 205 tires.
Koni sport (yellow) single adjustable shocks with high rate (can't remember the numbers) springs and adjustable height coilovers.
Front and rear sway bars with end links.
Roll bar and door bars (courtesy of the great guys at TDR).
I think that puts me in STR, but I couldn't find how the door bars affect classing. Also, it seems like I will be in at least CSP once I have my Momo wheel installed (350mm) so it may not matter for long. Hopefully the door bars don't put me above CSP.
Thanks for the help!
I believe that the door bars will push you into D Prepared. Check with any other CSP drivers at the event, they may not have a problem with you in CSP.
With more than 4 attachment points the roll bar with door bars is considered a roll cage, and it is legal for stock, ST, and SP classes as long as it is bolted in and not welded in.
If it is welded in it may be legal in CSP but not sure about that.
I have no problem with door bars in STR. I would love to see another NA in the fight.
Agree with conecerned - run in STR locally and we will have no problem with that. To me, a door bar is just a safety device anyway. The weight offsets the stiffness, imho. The replacement steering wheel is also not going to bother anyone locally.
I see its is a 97, but does it have a Torsen diff? If not, its basically an STS car with the same door bar caveat.
The rule of thumb is that if you are attending local events to have fun, we encourage you to sign-up in a class where you can have fun and there will be some competition, and small issues like the steering wheel or spoilers that don't affect the car's competitive advantage can often be disregarded if the other class drivers don't object.
If you get serious about the sport or you start dominating a class, it is in everyone's best interest to run in the
"correct" class. Much like golf, a little rule bending is fine for the casual player, but only hurts a serious competitor.
If you are new to autox, plan to run in the Novice class where you will have other drivers to measure yourself against. If you have some experience, come on over to the "open" classes, either STS or STR.
If you do move to CSP and are not running on R-comp tires, we have a "Tire" class where you can compete against many other drivers from various classes, but all on street tires.
Also, every club has slightly different classing rules, so ask questions. All of the clubs will welcome you regardless, so don't be intimidated about showing-up with whatever you drive. I attended my first ER event in a bone stock Yaris, and they didn't laugh too hard. :)
I was just told the door bars are bolted in.
I'm pretty sure it has a Torsen.
Sorry I wasn't more clear. This will be the Miata's first autocross, not mine. However, novice class might be the confidence boost I need to start off the season right! ;) (the car just became ready, otherwise I would have started the season much sooner!)
How much autocross have you done previously?
Thanks guys for the help. Just registered under STR. I'll be sure to have tech confirm that's valid. See you all there.
Tech is a safety inspection. They do not class cars. It is up to the competitor to make sure they are legal for their class. It is up to competitors to protest an illegal car or driver. If you have competed in more than 10 autocrosses then you might consider running in open class. I would also suggest running in a class where your car is legal.
Hey, Andy. Will you have your sound meter set-up for this event? I'm trying out something to make my car a little quieter, and if you are measuring, it would be more definitive than ears.
We will be running sound but we don't write anything down. You are welcome to have your lackey (JJ) stand by the sound meter and fetch and carry readings to you.
Is this event drawing participation away from the BMW event on 7/28?
I agree with JJ. Maybe 10 regulars who do both clubs. With these events being almost 100 miles apart, they probably aren't competing even that much.
Event attendance in 100+ degree weather is always down a little. I see this as a perfect example of how great the DFW autocross scene is: two days, two events, 2 different sites, one club with SCCA classing and tight competition, another with fun, simple classing and a TON of runs, both under $40 = Winning!
::Banana::It just goes to show how sick I am. I'm doing both.::Banana::
Thanks. I think I screwed something up... I logged in to the car/class registered, and now that I've changed that, it wants me to pay again, and I'm no longer registered for the event, even though I prepaid for the season. Help? :(
EDIT: I think I'll be driving the Miata anyway, I should have just left it alone..
Oh cool. The 'Total Driving Experience' Corvette thing, or something else?
Thinking about signing up. How many runs are there usually?
Thanks! I should be there.
We are considering a different grid location to speed-up staging and improve the ability of drivers to watch each others' runs. I'm posting both map versions, but the final decision will be made on-site. The only real difference is how close the course comes to the grid area.
I will make the BMW event but will be instructing in Ferraris and Lamborghinis at TMS on Sunday.
The tech inspectors don't really know all the classing rules except for the classes they run. B-Mod and ESP. The rule book is free download on the SCCA.com website. Just pick the classes that your Miata might be eligible for and then read what modifications are allowed for each class to see if it is eligible. The rule book gives allowed modifications so if it doesn't specifically say you can do something then it is illegal for the class.
