FS: NA / NB Parts (ECU, Wheels, Chassis, Electronics)
You can reply to this thread, PM me, or e-mail me at ravynx at gmail dot com. I reside in San Antonio, TX so you'll either have to pay for shipping or you can wait until I go to Mineral Wells, TX in two weeks for the SCCA Match Tour on June 15th-16th (this is assuming they are still having it if they get enough entries by this Monday (June 3rd)).
No dibs. This is first come, first serve.
Do not ask for deals, prices are already low and I expect them to go fairly quick; especially if they make it to MiataTurbo or ClubRoadsters. I'm trying to help local and track friends out first. ;)
Gauge Bezel: $40 obo
AutoMeter Oil Temperature Gauge (ATM-6156no sensor, electrical, 2 1/16" size (52mm)): $80
AutoMeter Water Temperature Gauge (ATM-6155, no sensor, electrical, 2 1/16" size (52mm)): $80
Mazdaspeed Miata Rear Sway Bar with bushings: $100
I was piecing together the suspension setup that 949Racing uses in their "grip-package". They use the MSM rear bar and the Racing Beat Front sway bar.
G-Force 6-point Blue Pull-Up Harness: $120
Expires 2015
G-Force 6-point Blue Pull-Down Harness: $120
Expired in 2012. Still good for HPDE events.
949Racing 6UL 15x9 Gen 1 Wheels with used Nitto NT01 tires: $900
NA/NB: These are the Gen 1 wheels that are gloss black center and spokes with a machined lip. They have 225/45/15 Nitto NT01s on them with about 1 to 2/32 of tread left but have plenty of meat after the tread disappears.
These items have Sold
Spare Koyo 55mm radiator (NB only) that has been repaired by COBB in Austin: $100 (Sold)
NB: I have not tested this unit as I bought a Koyo 37mm while the other one got fixed.
Innovate Motorsports LC-1 Wideband Setup: $80 (Sold)
Used for 20k miles
Blue Gauge
LC-1 unit and all the wiring needed
Wideband Sensor included
I also have the original box too
TopLoc (Hardtop Lock): $80 (Sold)
NA/NB: Comes with both keys, looks brand new
Flyin' Miata Frame Rails: $100 (Sold)
NA/NB: Used, no bolts
Sliding / Adjustable Seat Rails (I think they're from Memory Fab): $100 (Sold)
NRG Slim Hub & NRG Quick Release 2.0 (both are black): $120 (Sold)
NA/NB: Has holes drilled in the Slim Hub to accommodate NB Miatas
Hard Dog Harness Bar: $100 (Sold)
Reverant-built MegaSquirt 2 v3 with software: $800 (Sold)
Harness is for 1999-2000 Miatas
Info: http://www.miataturb...-90-05-a-60486/
I paid $815 after shipping just for the MS2v3 unit not including the $70 in MegaLogView and TunerStudio software, $15 in cabling (DB9 and 90 degree connector to avoid firewall), $20 GM IAT sensor. Check out the thread to see all the extra bits that Reverant from MiataTurbo includes on his MS2v3 builds. I had to wait nearly 4 months for mine since he's backed up with so many orders (he's not doing the group buy any more b/c of the amount of orders).
Koni Sports/Race and Ground Control 550/350: $1100 (Sold)
NA/NB: These are Koni Sport shocks revalved by Koni to Race-valving for the Ground Control 550lb front and 350lb rear springs assembled with NB tophats. These are plug-n-play and ready to bolt in.
