97 Miata - Alternator Belt Change Issue
I've changed many belts before although none with manual tensioners. I replaced my belts because they were worn and I got the Powersteering belt And the alternator belt. I got them both on without that much difficulty. The issue I'm now having is with the tension in the alternator belt.
The PS belt is nice and taunt with just a bit of deflection. I did the same for the alternator belt. Start it up and the squeal can be heard a mile away. I get under the car, loosen the alt mount bolt and mess with the adjuster and loosen it, while still not being super lose. Still squeals. I currently have it loosened to the exact point of where if I tightened the tensioner bolt anymore and then tighten the alt mount bolt it would squeal, yes I did it while the car was running. But the belt looks absurdly loose and Def more than when I took it off. I mean it ran for 10 minutes fine but It looks wobbly as it goes around the pulleys. I know it's the alternator belt squealing because when it was doing it, even after running it just for 10 seconds, the belt is hot to the touch and so is the bolt of the Alt pulley.
Right now it is set with no squeal but the alt belt is about 5 times looser than the power steering belt that doesn't squeal at all. I'm at a loss of what to do. And we have autox Sunday.
Thanks all
