Stuttering/Stalling Part Deux
Well it wasnt the fuel filter. Today while heading out to the TMS qualifying, the car did it again. Same situation, VERY hot, and crawling through traffic, so not much air flow. As I was slowly accererating in traffic I was at around 1500-2000RPM in third gear. Giving the car less than 1/4 throttle brought pinging. It did this in fourth and second also. A second later, the car bucked like last night. Next, the tach went crazy. Reving from 1500-3500RPM and back in less than a second. It did this three or four times then off. I pulled over and popped the hood. Again no obvious issues, wires loose, liquids, smoke, anything. I let the car cool off for a few seconds with the hood up. After maybe two minutes, I tried to start the car. It started up with some slight misfire, then smoothed out to idle. We drove to waterburger about a mile down the road and let the car cool off while we ate. The rest of the way to the track, traffic was light, and there were no more problems.
Any ideas? I am going to try and borrow my friends laptop with an OBD2 scanner this weekend and see if it is throwing codes. I did get my cat put on today, so that light should go out tomorrow. I didnt disconnect the battery to get it off so I could get any codes from yesterday.
