Coming home tonight the Check engine light came on, I will be taking the car down Monday to get the code #.
Monday????
Go now....
How can you sleep with that ::Censor:: light on?
Got a full weekend, it will have to wait til Monday.
It is distressing though....I need a break from the breaks.
Moderators note: The era of "I have a CEL" has come to an end. This post was moved to bull. All future posts lamenting the CEL and keeping us in suspense until the next full moon will be burned in a fire. Carry on. :-)
WoW
I'll just get the fix from Gary.
I think you missed the point.... We don't want to here about getting a CEL unless it includes the code that goes along with it. With the code, it can become "Miata Tech and Chat" as people offer advice on clearing a PARTICULAR CEL code. With out the code, there is no possibility of any real technical discussion, so therefore it is "Bull". Get the code, and then come back and post the code in "Miata Tech and Chat".
Hey Titus, you may make moderator yet! ::Clown::Quote:
Originally Posted by Titus
But seriously... Billy... If you're gonna work on these newer vehicles yourself you should go out & spend some money on a cheap eBay code reader... If not, at least drive over to your local Vato Zone, O'Reilly's, or other auto parts store & get the code read.
It'll at least let you know what is going on so if you take your other vehicle to a repair shop you can tell if they are trying to rip you off.
Thanks RJ....I think I will get one this is my 3rd code, and likely the same one EGR.
From what I have heard the code readers are relatively inexpensive.
Should it be the EGR, I guess I will have to take it apart and clean it...may as well do the paint on the intake manifold while its off.
Billy, tc isn't trying to be an ass, but without the specific code, we can't do anything to help but chime in saying "Gee, that sucks".
Get us the code, and we'll get you a fix.
Yup. Thanks, T.Quote:
I kinda look at it like this... Posting "I got a CEL" without having taken a ride by Vatozone is a lot like "My car quit and I think it's out of gas, but I haven't looked at the gauge yet."
Now... Feel free to post "I got a P0674" as many times as you want - granted, that the code for a bad #4 glow plug, so I don't expect that many times on a Miata board, but Code-diagnosis-repair-resolution reports are useful, since the more indications that Fix B cures problem A on electrical gremlins, the better we all feel about going through the trauma of applying Fix B.
My apologies if I was too brief in my initial gripe. :-) Cheers!
No prob, I guess I am just a little frustrated.
I was able to get by Autozone and it's the p0402? I think that is the code anyhow it's excessive EGR flow.
That's the 3rd time for that particular code, I really don't feel completely comfortable taking off the intake manifold and cleaning out the EGR hole but I guess I will have to get through it....since I am out of cash.
I have the info from Miata.net about how to clean it out, anything I need to get it done besides some cleaner, q-tips? is there a sealant i need etc?
Can you get one of those code readers that mounts in a pod on the A pillar?::Clown:: It might just come in handy.....IMHO::Clown::
A small zip tie or piece of weed-eater line works great for cleaning out the small hole inside the intake cover. No sealant/gaskets needed. Get a few cans of throttle-body cleaner and go to town. Clean the throttle body while you're at it. It's cheap and easy! (Just like some people I know ;) )Quote:
LOL
The reason I asked about a sealant is that I noticed when I got the car back that there was some red stuff that looks like permatex in the crack the separates the two halves of the manifold.
I picked up some permatex just in case, but it's good to know I wont need it....one less thing to do.
I plan on trying this later today or tomorrow afternoon.
Now that I think about it, I'm fairly sure there's supposed to be a permanent (metallic) gasket that goes in between the 2-halves. That's probably why there is permatex instead.Quote:
hhmmm....so if the metal gasket is gone will that affect anything?
I mean is there a drawback in using the Red Gunk instead of the intended metal gasket?
I think Billy would be better off with a HORSE.........................
You trying to sell me one of your horses Merv ;)
ok here on step # 11 there was only 2 bolts holding the bracket on.
What is this bracket for?
Unfortunately when taking off one of the hoses it came off hard and my hand came down and hit the refridgerant (sp?) hose and busted it so I have no A/C now :(
Damn Billy, if it weren't for bad luck, you wouldn't have any luck at all. Hope it's all an easy fix.
Well got it all back together and now the car ...after being reved up, will hang at 1500rpms then slowly descend to 1200rpms and then pulse between 1000-1100rpms.
I know it's supposed to idle at 900rpms, and I am pretty sure that I put the vacumn lines back in the correct order, however there was a ton of sludge in the offending hole and everywhere else on the manifold top so I am wondering if I now need to re-calibrate my idle?
Any help is always appreciated
Now that it's cleaned out, you may want to adjust your idle. There's instructions on miata.net garage on how to do so. Don't forget the jumper!
Sounds like there might be a slight vacuum leak too.
I don't care who you are that's just funny! ::Horse::Quote:
Originally Posted by MadMerv
I see flames in this horse's future!Quote:
Just re-checked the vacumn lines and they look to be right and no leaks.
I reset the engine light.
When cranking the car it starts with the idle at around 2K
............its just sparatic, I guess I will take it to Gary in a couple of weeks til then I am gonna let it sit so i dont screw something else up.
