AJ and I did a couple of "test" runs side by side and he still puts on me. I've got the light flywheel the sticky tires BBS wheels 2.5 catback air filter and rollbar. Why would his car be that much faster? :confused:
Lighter driver? ;-) J/K
Another possibility is different engines. Last time we all went to ATS for a Dyno Day, NA and NB engines could vary in stock HP by as much as 10-15%. His could just be on the higher end and your's on the lower. Just a thought...
The dyno knows fo sho! :albino:
S.
Doesn't BAM run a test pipe too? Stock cats are pretty restrictive.
Oooo... Makes me want to run against AJ. ::EvilBana
All kidding aside, weight might have something to do with it. AJ's car is pretty optionless, thus light weight.
Could also be the driver as AJ drives like that ALL THE TIME! ::Clown::
Next time you make some of these covert runs, be sure YOU initiate the acceleration. (Make him react to you.) If you keep ahead of him, it was driver edge. If he gains on you/passes you, it's his car.
Test pipes are fun, though!
AJ's car is pretty strong for what he has in it. He kept up pretty good when I had my 1.8-swapped 93 (with I/H/test-pipe).
The thing is if we do a roll on from say 30 mph I'll pull on him. But if we go from a dead stop I jump first and then he pulls on me. We thought about the cat and weight diff, but didn't think it would matter that much.
I think we should discuss over sushi.
when?
Lunch today.
can't make it today, got alot of crap to do before going to work
we did do that. plus i was power shifting. both runs were from a stop, where he got the jump and i had to react. he jumps in from a stop untill his back bumper gets to my front (or less) and then by the end of third ill be all the way out front. :burnrubr:
how much weight difference are we talking about, about 100lbs or less? car jack, spare tire, oil weight... i dunno just throwing suggestions...
hahaa, i do know bam spent a considerable time just waxing his car.. was it like a week or so?
that would be interesting to see the results of adding more weight... and if Bam still wins? then what, get someone bigger?
