I'm in! Who else? :burnrubr: LINKIE
I'll be pedaling out of the Speedway around 6:45 that morning en route to Sundance Square... Wave if you see me!
Make sure that you use your little ringer to let us know when you are riding by.
http://www.schylling.com/Great_Outdoors_w/BELLM-1.gif ;)
I'll be there.
Finals on May 5 and May 7, not this time for me :(
I will be holding on for dear life again :drive:
Ill be there but my parents are goin out of town so my dad will not be going
I will be there.... It is my weekend off!!!!
well my dad will be going after all.
OKay, we're in. Might as well burn off some of the OPR we picked up in Arkansas before we head for Houston. :wink:
Breakfast at the truck stop? 7'ish?
I'll be there, just hope the weather is forgiving. Saturday should be great, Sunday is still up in the air.
Of course I'll be there, planning not to be off course. See what I did there? Heh!
Breakfast meet is too far away. I'll see you kids at TMS.
I guess I was one of the few that liked the course. It was a great event, though. Matt and his group really had a smooth event today and got everyone out before any rain hit. Kudos. :clap:
Congrats to General Default on that BS win. That class really makes me want to buy an RX8.
Disappointed that none of you managed to join me for breakfast at the speedway... Apparently I was on the bike on the way out of Dodge by the time breakfast rolled around... Or, as Grampa Hal said... "I guess that's why I couldn't find ya!"
The event and venue were great! The course itself was meh at best. Congrats to jrj for taking 2nd in street tire (I took 3rd). POS won CS, the General won another tight BS battle and Mark52 won CSP. :clap:
And lost216 won ES.
I liked the course, so I guess I'm also one of those few. The entire event seemed to go well.
I walked the course twice in the morning, then drove 4 runs in the second heat. While watching runs in the third heat I finally realized that "The Safety God" had changed the final slalom between the times I walked and drove. I hadn't notice during my runs. Duh!
I got to meet several DFWMiateers in the lot after their session and before they had to work the 3rd (I was in the white NC). Nice to meet y'all!
I thought the course to be lacking in how it flowed, but again I'm not a designer, just a user. Kudos to all who helped us get out before the rain. I am still working on the proper set up for TMS. Ran 53's all day and could not get anything else out of it. I did pull of a 52 with two cones, so sloppy.
1 clean run out of 4. Yay! (Dee de Dee)
Nice day, had fun, see you mugs next month!
SA
Congrats to Jerrett, Sam, Hal, and Darron for being in the trophy spots for Tire class points standings. You guys are having a great battle this season. Still too early to see if there's gonna be a blow-out. My guess is, it will be close to the final runnings. Keep it up guys.
Nope, it wasn't me. I sucked yesterday. Think I heard the Old Bull say I was 9th and there were only 12 cars in Tire class not 25
Do you usually do well in the bus lot or is this par? I ask because I had a real hard time with the bus lot my first few races, but then I kind of figured it out by going slower. Same with La Grave Field -- I just watched car after car plow around turns while I was working on the course, so I just drove slower than I would have normally and went home with my first trophy.
The bus lot actually has a suprising amount of grip. I only managed to capture two runs yesterday on the datalogger before my SD card took a dump, but I saw transitional peaks of 1.35 Gs and steady-state peaks of 1.20+ Gs on the runs I did capture.
I am not an expert on data logging at all but after using a G-analyst I have some thoughts on peak G's. I think a peak G number that is not a duration of 1 second is not telling you much except that you were sliding the car and then it regained traction. So to say that the bus lot and MW have the same grip is misleading. 1.3G's is a high number to maintain on a stock car even with r-tires for a duration longer than a second on an autocross course.
If you set up a skid pad and had the same conditions I think MW would edge out the bus lot on a skid pad. But I don't have the data to back that up. Just an opinion.
New Hoosier racing slicks on BMod car at MW it was hard to maintain 1.2G on skid pad. You would get peaks when you let off the gas to close the arc.
Reading data from an autocross course is not an easy thing to do because things are changing directions so much.
It makes more since to compare two drivers data. The big numbers don't mean much most of the time. North American Pylon had a great series of reports about G-cube and GEEZ software on how to look at the data.
After recording video between two drivers I learned there is not much difference between two drivers. The difference is *** ***.
That little bit of info cost me some money so I am not giving that "go faster tip out". Us old guys have to have a few tricks to keep up with you young guys. Lets just say it does not take much to loose a 10th of a second.
Don't wanna share, eh? Okay, no more data for you to look at. :wink:
I realize peak numbers mean little, but they're fun to brag about. Comparing steady-state values through sweepers and 180 degree turns gives us a good indication of relative surface grip, though.
As for how just how little a mistake can be and still have a big impact on time, I agree. If I've learned one thing from playing with datalogging, it is how crucial every little part of the run is.
Lets see...
The Difference is More Cowbell. (We always need more cowbell.) :D
or
The Difference is Bigger Nuts. (He who brakes first isn't going fast enough.)
or
The Difference is No Fear. (What do you mean I wasn't suppose to be able to take the slalom flat out.)
Losing a 10th of a second is easy.
Getting a 10th of a second faster is hard. But that is why we do it. ::Banana::
So being new to this area how long does it take to post the results online?
I looked here http://autocross.com/texasregion/ Is that the wrong place?
GF got paged from work and we had to split as soon as runs in 3 were done.
Great fun though
Steve E
It all depends. If the auditor gets after it and the results are in pretty good shape they can be sent to General Default for posting that night. And usually posted the next day.
If the auditor can't get to it because of other demands for their time or if there are issues with the results that need to be figured out and corrected, then it could take longer.
The past year or so they have generally been posted within a few days, with a few occasions taking closer to a week. BTW, a proper audit of the results using the scribe and penalty sheets generated in the trailer will usually take 2 to 3 hours to do.
And yes that is where to go for the results.
No offense to Greg, but what a crappy course. This course ranks right up there with the 2006 Walnut Ridge Pro-Solo. Except in that event you were actually able to use the gas more than once.
