It still won't turn over... I seem to have power everywhere except the one place I need it - the starter. I think I have all the connections correct... I think.
Time to double check...
What!?!?! You're working on the BUR!??!?! :clap:
Yup...
Did'nt I remmember that you have a missing wire off of the wiring harness that went to the starter soleniod?
Maybe from the ignition switch?
Many eons ago I remember you posting somthing to that effect.
How about this for a problem...
Notice... the connector is on the correct side of the car, however, one has slots for 6 and the other for 5. But it is the correct connector... what the hell should I do now?
About where are those plugs located. It looks like a stereo speaker/ph\ower cable and maybe a center console connector.
It's hard to visualize the connector location in the picture you sent.
Nah... these were over by where the heater/blower would have been. However, they do provide power to the dash lights (got them working!) Here's what I did... I found the old plug (with 6 slots) and carefully disassembled it and the five slot plug, and methodically replaced each lead to it's correct position on the 6 slot plug.
Are you sure you have the correct wiring running to the starter box? I've heard that white cardboard will short out a wiring harness.. you need the ignition system in the same box as the starter, also.
:D
Bean,
Do you want me to send over the original "monkey"? :punchout:
Have you tried jumping over to the solenoid and see if all of that is working properly?
No need for the original monkey just yet... however, I have tested the battery (11.4 volts) and I'm getting all the lights on the dash to work. Gauges are registering and all lights are functional. She just won't turn over... I'm getting the click click but nothing more. All the connections are made (and I triple checked the connections on the starter motor.)
I'll check the manual for the solenoid test.
Is the starter good?
And after you've done that and if still not getting results, see if you can turn the engine with a socket on the crankshaft bolt (unhook the battery). Then try to start it. I had a situation once where the starter and flywheel just seemed to be in a lockup, and just a slight advance of the flywheel was all it needed.
Old fords, had the solenoid mounted separate of the starter and all you had to do is place a screwdriver between the two nuts on the solenoid.
At 11.4 volts, you are probably dropping voltage way down below 9.6 volts once you turn the ignition over. Hence the , click click.
I have a battery booster that I can bring right over.
Can you disconnect the hot cable that goes to the starter and then just place it on the hot for the starter. I will spark some when you first place the cable on, but should be ok. Of course make sure that its in neutral and that the key is off, WEAR safety goggles or sun shades and gas or other flammable stuff is NOT around!
It...
just started reading tonight...did it start?
Feels good, eh?
Woohoo!!
cam and Radio-Active came over and gave me a hand. Special kudos to Dave for solving the electrical issue! We took it out for a test drive and found a couple of small things and one large thing - some sort of wicked gas tank leak (perhaps the filler neck or somewhere in that area! The folks at 7-11 were staring when they saw all that gas hit the pavement. Ugh.)
Yeah!!! ::Banana::::Banana::::Banana::
Great to see it in action again.
Don't get rid of that wonderful schematic. It's a real life saver when trying to trace the wiring issues. ;)
Nothing like taking a June bug to the face at 45mph...
Way to go Beanie.....and to the guys that rescued him in time of need:clap:
Had a great time.
Hopefully I will be a little more coherant the next time, but what do you expect for being up 22 hours.
Did you figure out the fuel problem?
::Banana::Bring the BUR out Wednesday night!
Congrats!
:clap:
Who knew?
