Results 1 to 14 of 14
Thread: Flex install help
    Default Flex install help
    I'm really tired of always having the tallest car at the few meets I can actually attend! Anyone care to offer up a level driveway or garage, a torque wrench or three and some hands to install a set of Flex on my li'l white car?
    N.B.: With zero experience in this area of a Miata, I'll need all the help I can get for install and ride height adjustment.
    Food & beverages of choice are, of course, provided.
    Looking at any of the following dates in August: 25, 26 or 31.
    If you've never seen a short guy swear at inanimate objects, I swear it's a good time!
    I'm planning on putting my fender braces on this weekend, but I'll lend you a hand if I can.
    My garage is available, Someone will need to bring a big pry bar and some spring compressors, but i should have everything else you need, or we can always borrow. I live in Carrollton, PM me for more info
    Quote Originally Posted by Magma View Post
    Uhmmm...no need for spring compressors with Tein Flex. They are a one-piece replacement. Pull the old ones out and replace with the new ones. You'll still need that big old pry bar to push down on the A-arms.
    Nice, so much easier then
    So now you just need a bunch of guys standing around giving directions.
    I bet you'll even kick him in the ol' cabeza at no extra charge!
    Quote Originally Posted by 2K Miata View Post
    There is an easier way. Use the Hollis method and remove the long bolt from the upper A arm.
    Quote Originally Posted by cone-cerned View Post
    You and altiain can do it that way if you want... I still think it's easier to use the San Diego method. Rudedog's head was only damaged (was it?) because... get this... brake rotors turn!
    Quote Originally Posted by tailchaser View Post
    Add me to that list the bolt Hollis long bolt method rocks!
    Add me to that list the bolt Hollis method rocks!
    Good thing the fastener used to attach the upper arm isn't a screw...
    yeah I think we both learned that lesson
    +eleventyhundred.... I've done both methods more than once. The long-bolt is much easier.
    Used the San Diego method numerous times and found it very easy. YMMV.
    Thomas
    V-to-the-Dub
  1. Exhaust Leak at Flex Pipe
    By Screamin'Screw in forum Miata Tech and Chat
    Last Post: 02-15-2005, 12:22 PM
  2. FM Spring Install
    By tailchaser in forum Miata Tech and Chat
    Last Post: 01-25-2005, 11:52 AM
  3. Shipping my Miata to BR Performance for Coldside Install
    By Kags1969 in forum Miata Tech and Chat
    Last Post: 01-17-2005, 02:08 PM
  4. Good news and bad news (AGX install)
    By altiain in forum Miata Tech and Chat
    Last Post: 12-28-2004, 10:10 PM
