It's like Africa hot.![]()
It's so hot...
The trees are whistling for the dogs.
The best parking place is determined by shade instead of distance.
Hot water now comes out of both taps.
You can make sun tea instantly.
You learn that a seat belt buckle makes a pretty good branding iron.
The temperature drops below 95 F (35 C) and you feel a little chilly.
You discover that in August it only takes 2 fingers to steer your car.
You discover that you can get sunburned through your car window.
You actually burn your hand opening the car door.
You break into a sweat the instant you step outside at 7:30 a.m.
Your biggest bicycle wreck fear is, 'What if I get knocked out and end up lying on the pavement and cook to death?'
You realize that asphalt has a liquid state.
The potatoes cook underground, so all you have to do is pull one out and add butter, salt and pepper.
Farmers are feeding their chickens crushed ice to keep them from laying boiled eggs.
The cows are giving evaporated milk.
Didn't some guy's lighter explode in his car and burn it to the ground a day or two ago?
Black 2002 Honda S2000
Black 2003 Honda CBR 600 RR
Or maybe he ran over a piece of rebar that flipped up and lodged itself in his gas tank, driving almost a mile home before getting out of the car and carrying in the sick dog from the vet. All the while wondering what in the heck he heard pop up and hit his car while the dog had been bleeding on his passenger seat of his 6 month old 2006 Nissan Sentra. Next thing he knew, the car was engulfed in a ball of fire, sitting on his driveway.
A true story from a guy I work with. He now drives a 2006 Honda Civic EX.
Don't trust the news.
At least I wasn't making it all up.
Probably sparked the flint when it burst. You have to have some source for ignition.
Episode 65: "Exploding Lighter"
A lighter can explode on a car dashboard.
busted
The lighter was put in a toaster oven to simulate the maximum temperature that the interior of a car can reach, around 180 degrees Fahrenheit. There was no reaction for several hours, and the lighter finally exploded when the MythBusters ramped the temperature up to over 350 degrees Fahrenheit, well above any temperature that can be expected in the interior of a car.
Five hundred lighters packed inside a car can explode with lethal force.
plausible
The MythBusters placed five hundred lighters in a car and slowly heated it up. One by one, lighters began to rupture and release gas fumes. When the MythBusters finally triggered an igniter, the gas fumes exploded, blowing out all of the windows and setting the car on fire. The myth was deemed possible as long as there is a suitable ignition source.
