Results 1 to 19 of 19
Thread: Sick '91 Miata
    Another RARE Miata flyin94m's Avatar
    Nov 2006
    Double Oak, Texas
    Default Sick '91 Miata
    This morning, I fired up my Miata as I prepped for the drive to work. Cranking was sluggish and I attributed it to the cold. It idled fine. I drove out of the neighborhood and it still seemed okay. As soon as I hit the highway and gassed it, it bogged way down -- complete loss of power.
    I pulled to the side of the road and it died shortly after hitting idle.
    I started it back up and noticed that I cannot rev past ~5000 RPM. I limped home and parked it.
    Observations:
    1) I think this actually started happening yesterday on the way home from work but more at highway speed
    2) There's a high-pitched whine (almost a whistling sound) at high RPM (>5000).
    Recent changes:
    1) Oil filter and RP 10w30 2 weeks ago
    2) Filled the tank with gas right before I got home (after I started noticing symptoms)
    Outside of that, there's nothing major that I can think of.
    Things to check out:
    1) Fuel filter/fuel pump (courtesy of Dave04) -- I ran the tank a bit low before this last fillup. Perhaps there's some sediment that I picked up because of the low level in the tank. This doesn't explain the sluggish cranking (which really might just be attributed to weather anyway).
    2) Check the oil -- Looking for level, color, shiny stuff, etc
    I'm looking for any other suggestions that you guys might have or anyone who's seen this before.
    Thanks.
    Quote Originally Posted by Jeremy Clarkson
    There's no six-way traction control. There's no complicated folding metal roof. It's simpler than that. Engine in the front, drive to the rear, and a big smiling piece of meat in the middle.
    Currently:
    1991 Mariner Blue (daily driver)
    Previously:
    1994 M-Edition
    Clogged maybe?
    Chris
    http://austinmiata.com/
    a vacuum leak?
    Plugs and plug wires??
    Fuel filter is first suspect
    I'm gonna guess with Chris the maniac. Checking the cat is easy unless it's been welded on in the past.
    Nov 2006
    Double Oak, Texas
    Quote Originally Posted by Sharpie View Post
    The same thought has crossed my mind. I've been talking to the wife about picking up another FM cat and replacing the O2 sensor with it.
    Currently:
    Previously:
    1994 M-Edition
    Nov 2006
    Double Oak, Texas
    I just had a thought... I've heard a rattle over the last couple of days that I assumed was the heat shield on the cat. This rattle was missing this morning. Is it possible the cat broke up and clogged up the exhaust???
    Currently:
    Previously:
    1994 M-Edition
    Quote Originally Posted by Flyin94m View Post
    Doesn't sound unlikely (how's that for an internet diagnosis?).
    What do you mean another FM Cat? Is the one on there already an FM Cat?
    I wish you luck with getting bolts off, using plenty of penetrating spray and use some Copper Anti-seize on the new one.
    Chris
    Driver creek's Avatar
    Apr 2008
    Dallas, TX
    Blog Entries
    4
    I always check the easy things first.
    1. air filter
    2. alternator charging?
    3. fuel filter
    4. stubborn cat
    Before I get flamed I would like to point out about the alternator that the coil pack can pull down the voltage at high rpm if the car is running on the battery only. My money is on #3 but like I said, the easy things first.
    Stripe Das Sape
    Nov 2006
    Double Oak, Texas
    Quote Originally Posted by Miatamaniac92 View Post
    Chris
    I had an FM cat on the 94M -- Really liked it. I know what you mean about the bolts. I ended up just cutting the bolts on the old cat on the 94M.
    Currently:
    Previously:
    1994 M-Edition
    Spray'em down with PB Blaster and let them soak overnight. You may get lucky.
    Take the car immediately to MT for a new engine, a new transmission and a full chassis alignment. Don't forget your checkbook.
    Nov 2006
    Double Oak, Texas
    Quote Originally Posted by Snowdoggie View Post
    Don't feel the today.
    Currently:
    Previously:
    1994 M-Edition
    Where is the whistle coming from? I'd open the hood and see if I could hear it there before soaking everything overnight and buying a At 17 YO, you could just have on old vacuum hose leak.
    from a guy who pays for oil changes
    Nov 2006
    Double Oak, Texas
    I haven't had much time to look at it today but I did the following:
    Removed the air filter -- Yes, needs to be replaced, but not the problem spot.
    Checked the battery -- Read 12.76v. Threw it on the trickle charger anyway and it said it was done in about 5 minutes.
    Fired it up again (sans filter). It turned right over and idled, but really looks rough under the hood.
    While I was there, I throttled it a little until it bogged and noticed smoke around the exhaust manifold. I also smell gas.
    After it died, I tried turning it over again and it seemed to really struggle. It's not turning as quick as the first time and the starter sounds like it's trying harder than when I first started it. I'll let it sit for a while and try again.
    I'm still leaning toward a backed up exhaust, but will grab a fuel pressure gauge later today and try it out.
    I'm not even sure where to begin looking for a vacuum leak
    Currently:
    Previously:
    1994 M-Edition
    Nov 2006
    Double Oak, Texas
    After sitting a while it started again.
    I also crawled under and checked out the cat. It has puked -- I'm certain of it. I sprayed the bolts down with WD-40. I'll crack them loose tomorrow and run the engine without the cat to see if it makes a difference.
    Hopefully I'm not looking at both a cat and muffler.
    Currently:
    Previously:
    1994 M-Edition
    Listen
    Nov 2006
    Double Oak, Texas
    Okay. It's the cat. Pulled it. Ran down the highway full bore. Scared horses. Looks like I'm off to FlyinMiata
    Currently:
    Previously:
    1994 M-Edition
  1. Ken O? sick of it already?
    By Titus in forum Bull
    Last Post: 05-09-2008, 08:28 PM
  2. Call me sick but....
    Last Post: 01-29-2006, 02:11 PM
  3. These people are sick
    By jolberry in forum Bull
    Last Post: 11-05-2005, 12:13 AM
  4. My baby is sick
    By EvilSpeeder in forum Miata Tech and Chat
    Last Post: 09-22-2004, 03:04 PM
