Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: *sigh* If it ain't one thing... (Teg trouble)
    Default *sigh* If it ain't one thing... (Teg trouble)
    I've been living on the ragged edge of disaster lately.
    Last night I was coming home from the hobby shop in Dallas where I work (2nd job) when my Integra just up and dies on me on 635... so it's sitting there forlornly, right at Exit 22C (tollway).
    The car hasn't given me a lick of mechanical trouble since I've owned it; the only things I've done is routine maintenance (brakes, plugs, distributor cap, etc). Sure, it may be ugly but it's been perfectly reliable.
    I was cruising at about 70mph when I completely lost power and the car coasted to a stop; it felt almost like the ignition system went out. Once I stopped I tried turning it over, and it hit a couple of times at first but never hit again. The battery is new and I have plenty of power, so that's not an issue.
    What should I look for first? I'm going to try to get my manager to tow it either to the hobby shop where I can work on it or back to my house.
    Think it could be my Autozone distributor cap and rotor? Fuel pump? Any more ideas?
    09 Lexus RX350
    .... no Miata
    Quote Originally Posted by MadMonkey View Post
    Any more ideas?
    Timing belt/chain, BFH, blow torch (not necessarily in that order).
    I had an '88 Integra that did that exact thing to me once many years ago. It was the ignition system on mine. About a year later, I got a recall notice for the igniter. They replaced the replacement igniter that had gone in after the first one failed, and reimbursed me for the first repair and tow fees.
    Jul 2004
    Collinsville, TX
    blow torch
    TC, Altiain and I know how to use one of those now... We'd be glad to help!
    Dave
    "Opinions are like ..."
    I've been living on the ragged edge...
    Last night I was coming home from the hobby shop...
    Those are two phrases that are not typically seen together.
    I agree with Titus, I had the same thing happen to my 1990 Integra. Fortunatley the distributor is easy to replace and it's pretty cheap at the Vatozone. If I remember correctly it's 3 bolts and a little tweaking to get the ignition timing right.
    '06 RSX Type-S NBP
    Let's hope it's NOT the timing belt that gave way...
    That happened to me many years ago in my '88 CRX Si. $2500 later...
    Speed
    Welp, I'm off to pick it up... here's hoping it's nothing major. I'll go with the distributor first, probably. Thanks for the tips...
    09 Lexus RX350
    .... no Miata
    here's hoping it's all still there.
    Driver creek's Avatar
    Apr 2008
    Dallas, TX
    Blog Entries
    4
    94 Civic Si did the same thing to me. Coil was bad. Had hell figuring that out because it tested good with the VOM.
    Stripe Das Sape
    Welp, it's back home... I headed over there yesterday afternoon to check it over (in the light) and discovered that the contacts and the rotor in the distributor cap were VERY corroded. I cleaned them as best as I could with the tools I had, but it still didn't hit... luckily, there's a guy who shops in the hobby shop who happens to have a wrecker, so my manager asked him to take my car back to Grapevine, which he did last night.
    I'm going to pick up a new cap and rotor today and see if that's the problem. I hope so, I don't feel like putting a lot of money into this car just yet...
    09 Lexus RX350
    .... no Miata
    Quote Originally Posted by miataspeedracer View Post
    It shouldn't be the timing belt, because the Integra should have an interferance engine, if it was the belt it would have made some very bad noises.
    Quote Originally Posted by TurboDuane View Post
    When my belt broke on the CRX, it was not a noisy event...
    Speed
    When it died, it made no noises at all. The only thing you could hear was the RPMS dropping as is started coasting to a stop... that's when I decided that something might be wrong
    09 Lexus RX350
    .... no Miata
    Driver Ataim's Avatar
    Jun 2004
    About 7 miles north of Billy
    Don'y blame Onething.
    Don't forget the points and condensor.
    But seriously, check out the coil.
    Apr 2008
    Dallas, TX
    Blog Entries
    4
    The coil on mine was inside the distributer cap with the module, which I thought was the problem and changed first. No go. Replaced the coil and it fired right up. $54.00 at Vatozone four years ago if I remember right.
    Stripe Das Sape
    Quote Originally Posted by creek View Post
    Well, since the distributor cap and rotor need to be replaced anyway, I'll go for those first. If that doesn't work, I'll go with the coil.
    If THAT doesn't work, I'm completely lost
    09 Lexus RX350
    .... no Miata
    If those don't fix the problem, I would go looking into the fuel pump. My brother and my dad were both left stranded on the road side with there vehicles having a sudden fuel pump failure. One was an 86 Nissan Pulsar and the other was a 83 S10 pickup. You should be able to check the fuel pressure on the fuel rail with a gauge.
    Also you could check and make sure the cam is spinning by looking in the oil cap while someone turns the ignition.
    I just now replaced the cap and rotor, and it's still not starting.... guess it's on to the coil then
    09 Lexus RX350
    .... no Miata
  1. Sigh....
    By scorn001 in forum Miata Tech and Chat
    Last Post: 12-19-2007, 10:51 PM
  2. *sigh* my friend has clutch problems
    By BAM! in forum Miata Tech and Chat
    Last Post: 03-15-2006, 06:54 PM
  3. *sigh*
    By Dave04 in forum Bull
    Last Post: 08-07-2004, 09:41 AM
