Miata's eat thermostats. Make sure it's not stuck closed.
In normal driving, even when it's been hot outside this summer, my water temp gauge never moves past the 12:00 position. After some spirited driving or autocrossing, my water temp needle sometimes gets slightly warmer than normal (12:00 or 12:30 position... usually it's in the 11:30 position). Then, if I am idling the car, the needle swings pretty quickly to the hot end of the spectrum (1-2 minutes or so). When I see it start to move, I usually turn on the heat and it starts to cool back down. The needle has never been pegged and I never boiled any fluid. Things I've done or checked:
- Completely flushed coolant. Did the drain/fill procedure about 5 times until everything came out clean. It was pretty nasty when I bought it. Running 50/50 coolant/water.
- Replaced radiator camp.
- There are no coolant leaks and coolant level has not changed since filling.
- Fans seem to be working fine. I haven't checked the amperage, but when I put my hand behind the cooling fan it is turning very fast and pulling some serious air out.
Things that are left to possibly fix the problem:
- New thermostat
- New radiator (could be clogged?)
- New hoses (but wouldn't bad hoses give me problems more often?)
- New water pump
- Did I leave something out?
Given my symptoms, it seems to me likely that the radiator itself could be the likely culprit. It cools efficiently enough 90% of the time but it isn't efficient enough to cool the engine down when it is being stressed. And then when it is idling the fan just can't pull enough air fast enough once it reaches the point of no return. So, I think I'm going to go after the radiator first.
Has anyone had any luck with any radiator gunk cleaners? Thoughts about the best way to try and get a radiator unclogged? Or other thoughts related to my symptoms and diagnosing?
2013 Red Volkswagen GTI
ex Miata owner
2nd. And realize the stock gauge does not show actual temps. If it's running "slightly warm" it's pretty hot.
Oh, and if you find the radiator is a bit blocked, be sure to check the metal coolant pipe bolted to the inner fender - those get all kinds of crapped up. And I've always just pulled the radiator and back flushed it for quite a bit - I've never actually used a product designed to remove deposits.
Some people disagree with me, but miatas really like closer to a 70% water 30% antifreeze ratio. Try it, it's cheap.
Smile![]()
In Florida I ran all water, just about 2 cups worth of antifreeze, and a drop of dish soap. Changed that once I got out here and started seeing freezing temps, but I fully plan to run that again this coming summer.
* Aftermarket radiator, cap, ducting, AC and intercooler
Anyways, thanks everyone for chiming in. I think I'm going to see if I can flush the radiator out first before buying new parts. I'll test the thermostat too and see if it's a culprit.
ex Miata owner
Are the end tanks green or black? If green, I'd just replace the thing. I'd probably say to replace it anyway.
Flush the system real well with the old radiator in there, remove radiator and all hoses, remove and clean the metal pipe (2 bolts to remove when the hoses are off), new thermostat, install new rad, hoses, and cap. Unless you've got a bad headgasket or fan(s) issue, you should be worry free after all that.
Oh if you have AC, I would *highly* recommend taking a hose to the backside of the condenser when the radiator is out. Use a normal hose end on the high pressure stream setting, and go to town. You'd be shocked to see how much dirt and bugs get in there over the years/miles.
From what I've seen here, I think you can just get the hose from an NB. But I have yet to see that for myself, so I chose not to mention it.
