Spacers are legal. Buying wheels for your 1M already?![]()
I forgot. In SCCA Solo can you use spacers to get within stock offsets or must the wheels actually be within specs without spacers?
I think this says yes.
13.4 WHEELS
Any type wheel may be used provided it complies with the following: it
is the same width and diameter as standard, and as installed (including
wheel spacers if applicable) it does not have an offset more than
+/- 0.25 inch from a standard wheel for the car. The resultant change in
track dimensions is allowed.
13. STOCK CATEGORY — 73
Wheel spacers are permitted, provided the resultant combination complies
with the offset requirements of this section. Wheel studs, lug nuts,
and/or bolt length may be changed.
Vehicles equipped with rims having metric specifi cations may use alternate
rims as determined by using the following procedure:
Diameter: converting the metric measurement to inches and using
the nearest smaller inch diameter rim.
Width: converting the metric measurement to inches and using the
nearest smaller 1/2-inch width rim. Offset and track must still comply
with the requirements of this section.
M3 is always the answer.
Yep. ARC-8 look nice. Right size with a spacer and studs. Wanna buy a 335i?
I thought you were buying a Moustache.
