Results 1 to 6 of 6
Thread: rear window defogger
    Default rear window defogger
    I recently bought a 1995 Miata -- convertible with hard top. the hard top has a rear window defogger, but there's no switch for it on the dash. how can I find out is there is wiring set up to put in a switch/button for it?
    Everything should be there to connect it all together but you will have to add a few things. Here is the write up from the pointy board:
    http://www.miata.net/garage/hardtop/
    If it's pre-wired, there should be a pig-tail somewhere around the back window on the deck. I think it's on the driver's side, but not positive. The switch would be on the lower-left dash, near the cruise control main switch (if you have one). I might have a switch for sale, I'll have to check my parts box.
    My '94 M Edition has a power antenna, so I did not need the fuse block. But, I did need the defroster relay and the dash switch. Both were very easy to install. The plug for the pig-tail is on the drivers side, just behind the drivers seat.
    PS: If the number in your screen name is your zip code, you're a little too far away for me to come help with the install.
    Go check a junk yard, you may get lucky and find a car with the relay and dash switch. Also like has already been said, if you have a power antenna, then you already have the necessary fuse block. If not, go to a junk yard and look for a leather package car(tan interior), good chance of having the antenna and fuse block.
    PS, don't pay $120 on the OEM pigtail connector. Here's my solution to that...
    http://www.dfwmiata.com/showthread.p...hlight=pigtail
    Thanks everyonbe. I will be meeting with my nephew this Saturday to help with this issue! :o)
  1. some place to re-sew seam around rear window?
    By hangdog in forum Miata Tech and Chat
    Last Post: 11-23-2010, 06:33 AM
  2. Rear Window Clean up
    Last Post: 05-11-2009, 06:35 PM
  3. Gen 1 rear window defroster pigtail
    By Onceabuc in forum dfwMiata.com Classifieds
    Last Post: 04-16-2007, 05:35 AM
  4. WTB TCB - Rear Window
    By Screamin'Screw in forum Parts is Parts
    Last Post: 10-30-2005, 07:34 PM
  5. Tinting rear plastic window?
    By Chaz in forum Miata Tech and Chat
    Last Post: 07-01-2004, 04:19 PM
