will the struts and spring work on a NB?
**Springs/shocks sold pending funds.
**Shock tower bar and K&N Re-Charger kit sold pending funds.
Still have:
Clutch line
Latches
Water Pump
***Forgot I also have a braided clutch line. It's the short one, leaves the coiled hard line to the slave. Practically brand new, I had it installed for less than a gas tank. Took it to an autocross then car was broken down since then and I replaced it with the long line when I had to replace the slave.
I'll get a photo later.
-$20
Flyin Miata springs (the older, lower ones, 342lbsF, 228lbsR)
KYB AGX 8way adj. with tophats & bumpstops.
***Sold***
Top Latches
They've seen better days, but they are fine mechanically.
-$50
<93 CAS. I thought my CAS was dead so I used this one for testing. Didn't help my problem.
-$50
No photo, looks like all the rest.
Rock Auto water pump. Full disclosure, I originally thought the pulley surfaces were not machined right, causing the timing belt to track to the back of the pulleys, so I bought a new one. I had the same problem with the new pump so I think this one is actually good. Use at your own risk, I don't have the equipment to check the surfaces. Has some surface rust here & there from sitting in my garage in the humid weather, some steel wool should take care of it.
-$10
Ebay shock tower bar. Great surface for your ClubRoadster.net sticker.
-$10
K&N filter cleaner/oiler kit. Opened, but unused.
-$5
2005 Harkey-davidson lowrider
2002 miata
2009 klx250sf
ill take the shock tower brace. i'll take second dibs on the suspension if they will, in fact, fit an nb
http://i49.tinypic.com/4kvfc.jpg
Horsepower sells cars, Torque wins races - Carroll Shelby
Mods
FM front shock tower brace, OMP wheel, BBS Wheels, RZ ralco short throw shifter, Jackson Racing header, Racingbeat muffler.
Someone beat you to the shock tower, sorry. I'll put you second in line though.
The springs i'm pretty sure will fit an NB, but the shocks, i'm not sure what the difference is for NB, but I know there is one. Someone more knowledgeable might chime in, or i'll look it up later today. I believe the tophats are different as well.
What new suspension did you get?
CKerns' old Tein Monoflex. 10k/8k. Ohhh man it's nice. Feels like i'm driving a Lotus, well what i'd imagine a Lotus feeling like. Hopefully i'll make it out to the autox this weekend to try it out.
PMing you. I'll take the K&N recharger kit...
90 Red NA
91 Red NA
99 Triple Black NB "Dimples"
Will the top latches work on a '99?
SOLD - '91 BRG
^ Rosenthal's page says they fit 90 - 2002.
http://parts.arlingtonmazda.com/prod...2d310L%29.html
FYI, i'll be at the ER autocross this Sunday in Mesquite. If anyone is also going and wants to buy something let me know ahead of time and i'll throw it in the car.
From what I read they will bolt straight in to an NB, but will sit an inch lower than on an NA. Which would be LOW... Not sure if you can use threaded spring perches will help or not. Search on Miata.net, there's a couple threads asking about this.
Added stainless clutch line.
any pics of the springs installed?
There's a good one on my car domain Page in my sig. I'll post it when I get back to work.
has the shock tower brace been sold yet? or did you just not take it off the list yet?
Mods
^It's sold pending funds. Picking it up at the autocross Sunday.
Still have:
Clutch line
Latches
Water Pump
