Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Reasons NOT to get a C5 Z06
    The reasons TO get one are obvious. You asked for reasons NOT to get one, so here you go (in no particular order):
    • Tires are expensive
    • Seats are horrible for autox / track - zero lateral support
    • You WILL have electrical gremlins from time to time - expect a "Service Traction Control / Service Active Handling / Service ABS" message at some point. Usually a relatively easy / inexpensive fix though. Other random codes will pop up too
    • Everything in the interior is cheap plastic - lots of creaks, and things will break from time to time
    • The car looks dated, both inside and out
    • Oil and water temps get really high on on track - car would really benefit from an oil cooler / better radiator if tracked a lot
    • Brakes are insufficient for the track on r-comps
    • Lots of road noise / wind noise at highway speeds
    • Lousy cup holder (and only one of them) - expect spilled drinks
    • Bad gas mileage in the city
    • It's common for water to leak into the car SOMEWHERE when it rains - both of mine did this
    • Steering is numb, not very communicative
    • ABS "ice mode" kicks in a lot in autox - really annoying
    • If the car is lowered, the ride height, plus long wheel base, plus long front overhang means the car bottoms out / scrapes A LOT
    • "Skip shift" feature is super annoying
    • Ancient Bose sound system stinks
    • Shift knob is straight out of 1985 (who has square hands anyway?)
    • Seats are cheap imitation leather, and they will tear
    • Very few competitive street tire options in stock sizes
    • Car is not very fun to autocross on anything but the stickiest tires
    • Steering wheel is too big - belongs in a van
    • Steering ratio is too slow
    • Stock springs are too soft
    • Magnetic numbers don't stick to fiberglass - stickers are a pain
    • They like to eat cones at autox events
    • People will think you're a jerk
    I've also had to deal with:
    • HUD failure (huge pain in the butt to fix!)
    • AC compressor failure
    • Transmission issues - reverse doesn't work in mine anymore, and 6th gear pops out occasionally. Also first gear has become harder to engage over the years - synchros are probably worn out. Not sure how common these issues are though.
    • Reverse light switch failure - easy fix
    • Wheel bearing failure - wheel bearing / hub assemblies are kinda expensive
    • Oil pressure sensor failure - pain in the butt to replace
    • Broken seat frame (been living with this for a long time)
    It's actually fairly comfortable and practical as a daily though. Just a bit noisy for long trips for my taste. For reference, my car has 130k miles on it. Had about 45k on it when I bought it. '04 is the best year to get. Previous years had various other issues - some minor, others not so minor (oil consumption in '01s, valve spring failures in all but '04s I think...)
    Mark Wortham
    SS #197 - 2004 Chevrolet Corvette Z06
    Now THAT is how you do a write up!
    VW Bug in running shoes
    M Porcupine sedan
    M Porcupine coupe
    Crusty old e46 beater
    Battery Powered appliance car
    Wow. Just, wow.
    OK, lock it up.
  1. Possible reasons for check engine light to come on?
    By cArAzzIE in forum Miata Tech and Chat
    Last Post: 06-17-2008, 01:35 PM
  2. Top Ten Reasons to Own a Miata
    By randy7601 in forum Miata Tech and Chat
    Last Post: 07-11-2007, 10:15 AM
  3. Reasons for a rollbar at track days....
    By joe.MIATA in forum Open Track
    Last Post: 11-06-2004, 07:20 PM
