Results 1 to 7 of 7
Thread: WTB NA/NB front upper A-arm or front sub frame assembly
    Chassis Designer
    Oct 2010
    Grapevine
    Default WTB NA/NB front upper A-arm or front sub frame assembly
    Looking for an upper A-arm. Or if the price is right, a sub-frame with arms and knuckle(s) (only one side need be good/complete, doesn't matter which side).
    I picked one up at Mazda Nissan Heaven a couple of weeks ago when I messed up the upper ball joint bolt trying to remove it for bushings.
    You can check their web-site for parts.
    I "think" that these parts are different NA vs. NB. If you can get the whole front clip, the NB has a geometry advantage (so I'm told).
    Call Hugh at Ace Miatas and More. I know he has several subframes, including at least one that still has the hub and a-arms attached.
    Hugh's a good guy too.
    Chassis Designer
    Oct 2010
    Grapevine
    I bent one of my originals while attempting to remove the bushings using all thread and some nuts and washers and picked up a replacement at Ace. I think it was an NB as the ball joint was slightly different (longer threaded section). I'm planning on building a couple of new arms to provide greater shock/spring clearance. I was going to buy another arm to dimension off of, thought about getting the whole setup to build a jig out of to help ensure the new arms are identical to stock or at least as close as is possible.
    I can go back to Ace, just thought I'd check here first.
  1. WTB - NB Front Upper Control Arm w/ ball joint
    By EricJ in forum dfwMiata.com Classifieds
    Last Post: 01-02-2015, 07:06 PM
  2. WTB NA/NB front upper control arms
    By Johntron in forum dfwMiata.com Classifieds
    Last Post: 01-14-2014, 04:51 PM
  3. Replies: 2
    Last Post: 04-27-2010, 09:53 PM
  4. Front Frame Clip for 1990-97 Miata
    By cliff in forum dfwMiata.com Classifieds
    Last Post: 03-25-2010, 09:29 AM
  5. I need front upper ball joints/control arms....
    By icepenguin66 in forum Parts is Parts
    Last Post: 01-29-2007, 06:09 PM
