Was the slave leaking or have you been loosing lots of fluid in the reservoir?
I had a similar issue a little grease around the bleed screw kept it from sucking air. YMMV
I changed out my brake pads last night, and bled them whilst I was at it - and the clutch (and checked the torque on the suspension ready for S2K Sat).
I had immense amounts of air in the clutch fluid!! First it came out foamy...then just loads and loads of huge bubbles, long after new fluid was washing through.
Does this mean the master/slave cylinders are shot?(more $$$, reduced chance of convincing S.O. to let me have new tires)
Now I know you're really English!Originally Posted by Kiliwizz
What ho chaps, huzzah, rather! Don't get your knickers in a twist, but let's all have a nice cup of tea. More tea, vicar? (etc etc etc)
I didn't think of the bleed screw leaking, but then I don't have a mityvac so I'm blowing and not sucking. However, the fluid did get very low in the reservoir at one stage and I think I might have sucked some air through the system (d'oh)![]()
Had you noticed that the reservoir was loosing fluid prior to bleeding the clutch? Was the boot wet on the slave itself??
No, there wasn't any noticeable fluid losss, no wetness, I squeezed the boot and no fluid came out. The fluid was black, but I understand that's just ageing of the rubber o-seals etc in the system.
The later bubbles may be due to me running it dry, early ones weren't - and they the fizzy bits!!
The blacking of the fluid is coming from your rubber clutch hose, replace it will give you a more solid linear feel. Slave cylinder kits are about $7-8 dollars from the local auto parts store and are a no brainer to rebuild, a one minute job, pull the old part out and push the new part in (more or less). I do stock the braid clutch lines.
Gary
Danger!!! This Dog Bites.
www.trackdogracing.com
I'm guessing he is pressure bleeding...Originally Posted by blackzx3_13
No more Miata
Originally Posted by jolberry
Nope he is doing it old school!Originally Posted by Kiliwizz
Originally Posted by From the Miata.net Garage
Sounds like fun...(takes a lot of running around the car)
No more Miata
