Bought a new pressure cap yet?
A few days ago I started smelling 'that smell' but the temp gauge hadnt moved at all, I blew it off as I had the top down, must have been another car. Next day I smelled it faintly, popped the hood, couldnt find or smell anything, hmmm...must be in my head...
Today on the way to work, I had the barndoors up & started noticing a small amount of steam comming out of the drivers side barndoor while at a rather long stoplight, still the temp gauge stayed in its normal spot, slightly below half.
Pull in to work(noticed it pretty close to work, didnt drive it to far like this) pop the hood, didnt see any steam(engine was running), but saw small amounts of coolant on the headlight housings, both sides, & all around the top of the radiator, but no indication it was comming from the cap, or a hose.
Any way to check whats causing this, without having to pull the front end off the car??
This is the first time ive ever had any issue with the cooling system, other than blowing a heater hose from a leaky CAS. I hope the radiator isnt cracked, I cant afford that...
OH yea, forgot to add that, flushed coolant & changed the cap / thermostat about 7 - 8 months ago.
I think so, the top is brown plastic.
Sure sounds like a radiator on the way out.Originally Posted by Jiggerachi
You may want to drop TurboDuane a PM I think he had a team CB radiator available!
I might have a all metal radiator that I can let go cheap. I just have to make sure the winner of the ebay auction really can't pay for it. Said he had some bank problems.
Let me know. I'm looking for $60, that's what it went for on Ebay.
Thomas![]()
V-to-the-Dub
Well, looks like my cooling woes are over, for now, much thanks to TurboDuane
The leak got much worse last night on the way to TDs house, I ended up loosing most coolant on I20 at the Great Southwest on ramp, talk about a bad place to break down! Let it cool off, poured the last of my spare water, limped it to a gas station, filled her up with some overpriced water, & limped it the rest of the way.
We swaped it out in a little over an hour, & all appears to be well now!
Glad to hear it and to help keep you in the running for President of TCB![]()
