CAS O-Ring suff!
CAS O-Ring write-up!
There was a link to this on the pointy board, so I placed it here for future reference! I need to replace mine!
Looks like a good tech day project! Then we can see 'how-to' retro install factory cruise after that!
i did mine, it was pretty easy taking it out, but putting it in sucked. its hit or miss, and most of the time it was miss. i did it without taking the valve cover off. all i had was a little mirror
I second the putting it back on is a pain. I also found that some of the bolts near the back of the valve cover were loose. It might be a good time to check those while you are there.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
