Results 1 to 17 of 17
Thread: Merv, I need a part...
    Exclamation Merv, I need a part...
    I'm hoping you have a dash wiring harness available?! Let me know if you do...
    Quote Originally Posted by Treibenschnell View Post
    Must not comment.... must not comment...
    Did you misplace a Box??
    Not to mention the CEL light didn't come on when you turn the key 2 clicks.
    Nope... I've got 12V all over the car... lights are working but I can't hear the fuel pumps priming nor will it try to start over.
    Basic stuff, but did you check all the fuses and relays (the ones under the hood too) ?
    Yup... I have a couple of extra, new relays that I was swapping around... Titus was helping me track down some of the other loose ends. The harness to the motor is complete with all connections made.
    So is the car still blue?
    Ignition switch perhaps??
    we are thinking the dash harness because we spotted a wire removed from it (in his search for added lightness) that looked like it went to a pin on the instrument cluster that was labeled IGN.
    I don't think so... I'm getting voltage on. But perhaps I'm not catching your drift...
    Quote Originally Posted by Sharpie View Post
    Yup... college zapped my poorly laid plans for reconstruction.
    Have you checked the ignition switch with a meter to see if it's doing what it is designed to do?? My thought is the fuel pump (& CEL) comes on when ignition is switched on.
    Sorry I haven't gotten back with you Bean. I think you have my only available spare.........
    Quote Originally Posted by MadMerv View Post
    I got the big harness (that connects from the motor through the firewall to the ECU and such) from you a while back (and it worked fine!)... the one I'm looking for is the one that resides under the dash, attached to the dash.
    Thanks again, Merv!!
    I thought you got all of it. Maybe I do have what you need. I will check when the barn warms up................
    I appreciate it!
  1. Too Tall, Part II (or New Dog, Old Tricks)
    By Monkey of Death in forum Miata Tech and Chat
    Last Post: 11-03-2006, 12:00 PM
  2. BoostedNB's Turbo Miata part out
    By BoostedNB in forum dfwMiata.com Classifieds
    Last Post: 09-02-2006, 10:45 PM
  3. hey Merv?
    By BAM! in forum dfwMiata.com Classifieds
    Last Post: 08-11-2006, 03:17 PM
  4. Help with part number "Tailshaft Oil Seal"
    By TurboDuane in forum Miata Tech and Chat
    Last Post: 09-25-2005, 12:57 PM
  5. Seat foam-ectomy - Part II
    By sammm in forum Miata Tech and Chat
    Last Post: 03-16-2004, 06:07 PM
