WHOA now...
I've done 2 timing belt/water pump jobs and have never had to remove the nose, radiator, or AC parts... just move the compressor out of the way.
It's easier if you get under the car and remove the 4 bolts on the sway bar mounts so you can push the sway bar down to get to the crank bolt and have room for a pulley puller if needed.
Raymond
