Are you sure it is bad? That one should only come on if you turn the AC on. Cars without AC don't even have the second fan.
need a radiator fan if anyone has one laying around, the one on the driver side went out.
Its the fastest who gets paid... and the fastest.. .who gets LAID!
i know but POS Racing said on another thread that the pass side is the AC fan and that one does come on when i turn on the AC.
but the driver side fan is got dislocated and i could not turn it with my hand. i tried to fix it but it didnt work.
O'reilly sells replacement fan motors for around $75 each. I know that isnt a bargain, but it is probably much better than what mazda wants.
If FORREST has one in his part out car (see other thread) would the 99 fan fit in a 91?
Black 2002 Honda S2000
Black 2003 Honda CBR 600 RR
does anyone know if both fans are the same, or are they different (can i buy a ac fan for a reg. fan?)
I suppose you could fit the a/c fan in place of the main unit if you really wanted to do that. I'm not sure how effective it would be, though. There is a size difference between the fans, and I can only assume that they flow different amounts of air.
You're welcome to mine if you want it. However, you'll need to grab a couple of butt connectors or solder and heat shrink, as I used the connector on another fan. It came off of a '92, so it should fit perfectly.
Haha, he's gonna be happy!
wow thanks for the info. when can i go and take it off your hands?
ill just use my old connector off my existing fan.
pm sent.![]()
