Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: how do you find a short with the multimeter
    Default how do you find a short with the multimeter
    I should show infinit resistance when contacting each side of the fuse terminal with the probes right? Then, when I find the deadshort, and eliminate it, I should see a +-50ohm value right?
    I can't seem to find my short in the "tail" circuit. I guess I will just start taking the car apart and look for a jacked up red/blk wire right?
    and thanks for help.
    Try submerging your car in water and looking for the bubbles. Much faster.
    Check for continuity, not resistance (underwater gives faster results too).
    Quote Originally Posted by tailchaser View Post
    Dang I spit coffee on my monitor and keyboard!
    also... in order to save weight... Mazda included only a VERY small amount of smoke in Miatas. If any let out because of the short, you'll need to replace that before the lights will work properly.
    if I have a deadshort after the fuse box, I should be able to pull current when jumping from a power source to after the fuse box right?
    Jul 2004
    Collinsville, TX
    Doing this will likely let out lots of the precious smoke that TC mentioned above...
    The best way you are going to find a short in a DC system like this (especially when the common ground is the body of the vehicle) is through a visual inspection.
    EDIT: on second thought... if you do what you recommend (with a big enough battery) you will quickly find the short because that's where the fire will start.
    Dave
    "Opinions are like ..."
    Quote Originally Posted by Dave04 View Post
    multimeter ftw.
    I guess I'll just start stripping the car since the roll bar is about to go in.
    Was it the frayed wire you found yesterday that was causing the fuse to blow??
    http://forum.miata.net/vb/showthread...1&page=1&pp=25
    btw, did I mention that this totally sucks?
    Was it the frayed wire you found yesterday that was cousing the fuse to blow??
    apparently not. I check it again today, and its still taped up. I thought that was the problem because I put another fuse it in and it worked for a day.
    sorry I made a mistake. I wish I hadn't.
    Have you added anything new to the car recently??
    Do you have an aftermarket horn?
    Quote Originally Posted by channelmaniac View Post
    Yep. The horn and the tail lights share the same fuse.
    no
    I have to check the horn, again...its stock btw.
    and don't forget the mirrors!!!!!!
    Same here!!
    just double checked...the horn does work. Atleast when I get out of work today, its like the most perfect day to have car issues. So nice outside.
    Plus you can confirm the location by looking for bubbles after you submerse the now burning car in water... which you should have done in the first place.
    ...or you could park it on I820, across from Hiley Mazda.......
  1. Replies: 2
    Last Post: 04-11-2006, 04:21 PM
  2. Where to find mirrors...
    By Treibenschnell in forum Parts is Parts
    Last Post: 12-26-2005, 10:31 AM
  3. New way to find parts!
    By rx7gslse in forum Parts is Parts
    Last Post: 05-13-2005, 01:58 PM
  4. HELP Lincoln Town car, how to find original combo lock code.
    By TurboDuane in forum OTM Tech and Chat
    Last Post: 03-30-2005, 11:27 PM
  5. Where to find a GSP 9700 to balance your tires...
    By channelmaniac in forum Miata Tech and Chat
    Last Post: 03-01-2005, 11:53 PM
