SO the next time the guy at Discount tells you an impact gun is okay...
		You can tell him this. :wink:
I’ve been attending a seminar this week on fastening technology and bolted joint design (hey, I’m an engineer. It’s what I do.) Anyway, one of yesterday’s subjects involved bolt tightening methods, and how to account for tool inaccuracy when designing bolted connections.
One of the numbers that stood out to me was this: with a well-maintained impact gun, the best accuracy you’ll ever get is +/- 60%. In other words, if your lug nuts have a nominal torque value of 80 ft-lbs, then even if that monkey down at Discount has a brand new gun and sets it properly (which they don’t), you could end up with nuts torqued anywhere from 128 ft-lbs to 32 ft-lbs. Using a “torque stick” doesn’t make a bit of difference in this scatter.
So, just a reminder: always make sure the monkey at your local tire shop reinstalls your wheels by hand and torques them with a torque wrench. This isn’t a perfect method, but it’s a lot more accurate than an impact gun, regardless of what the monkey tries to tell you!
