Originally Posted by
jdcanadian
ok folks, here goes...
about a month ago, i replaced the OE coolant overflow tank because i saw coolant leaking... everything was good until....
this past weekend at the 5-star ford ECR event, during each of my first 20 minute runs, almost all of the overflow tank volume had disapeared.
-there is no coolant coming out of the radiator(i pulled the hold-downs and looked)
-the inner floor is dry, as is the heater core/AC drain line.
-the heater lines at the firewall to engine are dry.
-the little hoses under the thermostat are dry.
-it's not boiling-over, frame area is dry(coolant doesn't evaporate quickly, and leaves residue).
-the under tray is dry(not from the water pump).
-the temp gauge has been stable and happy.
sounds fun eh?
it's obviously something internal, as i saw green mist out of the tailpipe...
has anybody had this? is it the head gasket or the head itself?
so, what do you think?
Jerome.
