Just finished putting a PWR radiator in.
Had the car completely disasembled and noticed a problem. The PWR obviously needed brakets but looking at the radiator that was in the Miata there were none. Stupid Cheap Aftermarket POS. ::Rant::
Quick call to Gary verified my worst nightmare. He gave me a couple of numbers to call but had no luck. Unable to find the brackets I decided to try something else.::BaHump::
I used a 1/2 inch wide wood chisel to remove the mounting brackets off the POS radiator as they were literally glued on. Messaged them with a little TLC (and a big hammer) and drilled out a hole for the mounting screw on each side. To top it off I installed the TDR radiator shield. Everything lines up and fits perfect. :burnrubr:
Best thing. There are no leaks.:D
