Where you live, if you have the room to do it at your place or need to use someone else's and such will help attract folks.
				I was curious if someone could help me change out the transmission fluid in my 1990 miata. I have never done it before and mainly just want someone to watch over me. I havent changed the fluid since i have own the car and my tranny feels clunky at times (no grinds).
There is a detail write up in the pointy board. If I can do it, you should have no problem to do it yourself. Just make sure you have the correct size wrenches, fluid pump (Harbor Flight has one on sale for $5) and jack stands. The main thing is to make sure you can open the fill plug before drain plug. You sure do not want to drain it all out and can not refill it back.
Hopefully, this will help.
1999 Miata
2003 MIata
1999 Miata
2001 Kia Rio
I changed mine lately. The fill plug was not difficult to remove but it was 16mm. First time I ever used that particular wrench. First time for everything I guess. Royal Purple made a big difference to a trans I thought was shifting fine. Great Stuff.
Stripe Das Sape
				i was going to do it at my grandparents shop in crandall. I live in mesquite though. Im new to miatas i used to have a DSM so im learning about the miata now. If someone has a shop or a place to do it and they wouldnt mind lunch on me and a case of beer or dr. pepper.
I have found that a 9/16 in. 8 pt Socket works on the square transmission fill plug.
You may want to order new shifter boots, there is a big one and little one, and make sure to fill the turrate, they're almost always dry.
Smile![]()
It's easy, just need some ramps or jack stands and some hand tools.
VW Bug in running shoes
M Porcupine sedan
M Porcupine coupe
Crusty old e46 beater
Battery Powered appliance car
				By the way my name is Chase thanks for the input. My car is completely stock with a drop in K&N and sportmax/XXR 002's. i will get some pics up later. Do any of yall go out to mineral wells for the drift events or do yall tend to just autocross?
M Porcupine sedan
M Porcupine coupe
'96 "R2 Limited" | On Minkara
'99 s/c - Sold | Club Roadster Calendar Car: August 2011 | Roadster Garage Roadster of the Week
				2 tires sideways in the seat one behind the seat and one in the trunk!
