I plan to be there. Regardless of the course, I will be there early to help set it up.
I know the course with the pivot cone (I designed it) and it presents an interesting challenge because you have to determine the best line with little to assist you. The same turn could have cones for a line that is more defined and you would not complain. By not having any definition, then it is up to you to determine the line and make yourself abide by it -- the pivot cone will pull you in at the wrong place. Embrace the pivot cone. Be the pivot cone. Smoke the pivot cone. Only then will you become a PCA autocrosser.
